Building a pair of new 555's >
Old 01-12-2017 | 05:38 PM
Originally Posted by snapmorgan
800 Holleys to start out with, because that is what we have. Will see how they do on the dyno and go from there. Being prepped now by Ken Jones performance. He is somewhat of a legend around the Midwest, but mostly in his own mind. I will most likely end up with fuel injection on mine if it turns out that I like this boat.
The 8-71 has a chiller, I would put one on the 420, but where would I find one?
Teague has them new of course. But, sometimes you can find them used cheap. Having a chiller, will really make for a great comparison build to build.
MILD THUNDER is offline
Old 01-12-2017 | 05:39 PM
Originally Posted by Boatally Insane
Here is a link to my 555 build for reference..
That is pretty badass
snapmorgan is offline
Old 02-13-2017 | 08:58 AM
I am considering putting mechanical fuel pumps on these engines. Is anyone else doing this on 800-900hp engines? What are you running?
Old 02-13-2017 | 09:01 AM
Short blocks are done, cams degreed. I set of heads here today and getting ready to be installed
Old 02-13-2017 | 09:02 AM
Yes. The baker engineering mechanical pumps.
Old 02-13-2017 | 09:14 AM
I`m running a baker mechanical pump with a regulator and tank return. -10AN lines
mild is running the Holley pumps self regulated and no return and it seems like no issues.
I was running out of fuel pressure with those at 6000rpm. Fuel gauge would start to drop to 4psi till I`d let off.
ICDEDPPL is offline
Old 02-13-2017 | 09:31 AM
Do you know the GPH needed?
Old 02-13-2017 | 10:42 AM
The 900sc and 1000sc mercury engines, used those style mechanical pumps. Fed two dominators at 6000rpm.
Old 02-13-2017 | 11:41 AM
http://www.bakerengineeringinc.com/P...oCamParts.aspx
ICDEDPPL is offline
Old 02-13-2017 | 05:17 PM
Where did you have your regulators set? Just wondering if you had set to the max flow, I'm running mechanical pumps on sc build with dual carbs and have the regulators but wasn't going to bother even installing given the new build. Mainly just to eliminate plumbing.
getrdunn is offline
