So The Hell With It, Rebuilding 502, Need Some Direction >
Old 05-25-2018 | 08:06 PM
Originally Posted by liberator221
810-324-2720
Thank you
Dutchboy is offline
Old 05-25-2018 | 08:07 PM
Originally Posted by AllDodge
Nothing tuns perfect, so over time the cylinder will be a bit deformed, how much depends on many things. If your going to build/rebuild a motor, IMO you want to start fresh. Take as little as you can if that's the issue. You can still buy brand new 502 blocks, even from Summit for under 2K
Here is a good read,
502 overbore, how far can it go?
if I'm gonna spend 2k on that, might as well buy aftermarket
Dutchboy is offline
Old 05-26-2018 | 07:39 AM
Sorry but maybe were missing each others point. You don't want to bore because the blocks are hard to find. I said you can still buy new ones, and also the thread where some have bored .10 over, so yours could be bored again some day.
AllDodge is offline
Old 05-26-2018 | 08:14 AM
What tells you if it needs bored isnt the fact its apart, its the condition and measurements of the bores, If its well within tolerances and in good shape, its within tolerances and in good shape,
phragle is offline
Old 05-26-2018 | 10:39 AM
A few years ago 502 blocks would pop around here (dallas) every once and a while. for 500-1000 bucks. I just don't ever see them anymore. I had no idea that summit still sold them, I got what you were saying, I just couldn't see buying for 2k when after market isn't much more. Your right though, if I had to bore hopefully its just .010, seems like the go to for everyone is .030. I'm glad I read that link that was shared.
Dutchboy is offline
Old 05-26-2018 | 06:00 PM
I may have a set of low hour JE forged forged flat top pistons that are .002 over stock where a good hone with a torque plate will get you there. If you’re interested I’ll double check. $125 shipped.
A 500EFI cam should get you to 500hp without having to reinvent the valve train.
Baja Rooster is offline
Old 05-26-2018 | 08:21 PM
Awesome. I have decided that I am going to stay EFI this summer. Its the fastest way back to the water for me. If you don't mind, let me see what the machine shop says, will these raise my compression? With a 500EFI wouldn't I need a 500EFI computer?
Dutchboy is offline
Old 05-26-2018 | 09:35 PM
I’m in no hurry. If you were within driving distance I’d just give them to you.
I believe eve they are these. 281916 Product Detail Information - JE Pistons
Old 05-26-2018 | 10:04 PM
I'm in Dallas Tx. I appreciate it. I'm sure that I will need the hone.
Dutchboy is offline
Old 06-06-2018 | 07:56 PM
Well, It needs to be bored out, honed it .002 and on one cylinder it didn't even touch the top 3 inches. Anyone have any recommendations on pistons? I think Im going to have to go to a 4.500 piston.
Dutchboy is offline
