Bbc 454 build.
Old 04-09-2019 | 12:07 AM
  #91
Originally Posted by JaniH
We have RON 95 E10 (10% ethanol) and RON 98 E5 (5% ethanol). Usually all marinas have Ron 98 E5
98 RON is about equal to 93-94 in the US, so I'd stick with 9.5-1 or so CR. I have seen higher run on that gas, but I like to make errors on the caution side.
Zone 5 is offline
Old 04-09-2019 | 12:44 AM
  #92
If i am undersrtood right, the dynamic compression ratio should be arround 8.0 or bit more.
JaniH is offline
Old 04-09-2019 | 07:50 AM
  #93
you can go 10/10.5-1 compression.I ran 10.3-1 for years on iron heads and 93 octane.
sutphen 30 is offline
Old 04-09-2019 | 01:57 PM
  #94
In very general terms, yes. Big difference between Dynamic and static CR.
Zone 5 is offline
Old 04-09-2019 | 03:06 PM
  #95
Just bought Summit brand 308cc rec-port heads. Used under 20 hours. could be same as Dart iron eagle 308cc
JaniH is offline
Old 04-09-2019 | 05:24 PM
  #96
SB
summit brand cast iron BBC is from Dart,
the 308's need 4 different cam lobes.
SB is offline
Old 04-09-2019 | 07:29 PM
  #97
very good choice,one million times better than the peanut port gm head.
mike tkach is offline
Old 04-09-2019 | 08:31 PM
  #98
You just made your goal a million times easier to reach.
Zone 5 is offline
Old 04-10-2019 | 05:40 AM
  #99
This intake came with the heads. Cant find any casting numbers.
JaniH is offline
Old 04-10-2019 | 07:23 AM
  #100
Not sure if it's ok to post this
but if any problems with your big block?I have 2 new 454 HO rectangular port one with new intake & stainless marine exaust!Sorry for the hi jack!
Nothing personel 353 is offline
