Bbc 454 gen 4 overhaul
Old 11-10-2020 | 05:40 AM
  #91
Default Build
Ok that sounds great thank u a for the pulley I have no idea i bought from Jeff Wallace on here I have not received parts yet still in shipping he lives in Cali I live in ky gonna take a hot min but I will ask him the pulley looks pretty small not much over 3" if I was to guess from pic
Your guess is as good as mine
Baja 250es is offline
Old 11-10-2020 | 05:44 AM
  #92
Default Build
I'm calling machine shop this morning to check on my heads progress see how they are coming along I will update as I know once again thank you for your much needed help glad I joined this site
Old 11-10-2020 | 08:40 AM
  #93
mcollinstn's Avatar
Let your shop know you're running a blower. Typically, you will want to run a little thicker seat width on the exhaust side to pull more heat out of the valve. At 5psi, it's not a must, but it's a good rule of thumb. (Unless you're running inconel exhausts..)
mcollinstn is offline
Old 11-10-2020 | 11:45 AM
  #94
Default Build
If you don't mind me asking why the tie bar style
Old 11-10-2020 | 12:55 PM
  #95
There's a pad machined into the block to make room for the dog bones and the spider retainer to bolt in place. Tie bar is easiest way around it. Nothing at all wrong with tie bar lifters.
Smitty275 is offline
Old 11-10-2020 | 01:07 PM
  #96
Default Build
Ok cool i didn't know just curious
Old 11-10-2020 | 01:15 PM
  #97
Ok. Just asking at this point. A 2:1 (ex. 3"upper/6" lower) overdriven ratio will get about 5.5# of boost on a 454.
Griff is offline
Old 11-10-2020 | 01:17 PM
  #98
Default Build
Ok that is what Jeff said it was set at that's all I have to go off of until parts arrive
Old 11-10-2020 | 05:59 PM
  #99
Default Build
All 4 corners of first piston measured
Old 11-10-2020 | 06:00 PM
  #100
Default Build
2nd piston all 4 corners
