Bbc 454 gen 4 overhaul
Old 11-10-2020 | 06:13 PM
  #101
Default Build
3rd piston
Baja 250es is offline
Old 11-10-2020 | 06:14 PM
  #102
Default Build
4th piston
Old 11-10-2020 | 06:18 PM
  #103
Default Build
U think she needs to be decked lol
Old 11-10-2020 | 06:34 PM
  #104
Default Build
Rt side
Lft side
Old 11-10-2020 | 07:16 PM
  #105
How are you measuring? Depth mic?
sailtexas186548 is offline
Old 11-10-2020 | 07:32 PM
  #106
Default Build
This was an earlier post
Old 11-10-2020 | 07:34 PM
  #107
That puppy is all over the place. Someone did a piss poor job resizing the rods to have that much variance. Can only cut it to the highest piston.
Smitty275 is offline
Old 11-10-2020 | 07:57 PM
  #108
Default Build
So the most i can take off is .10 across the board and run the thinnest gasket i can find correct
Old 11-10-2020 | 08:08 PM
  #109
Default Build
Will i really notice the difference if I send out tell them to make sure it's true and flat cut .05 off on both run thinnest gasket and call it a day or is that a bad idea I mean the boat ran good before I tore apart but I did not have a blower before either
Old 11-10-2020 | 08:57 PM
  #110
No (assuming you mean .005) at best it will help head gasket sealing.
a set of scat I beam rods with arp bolts is under 400 bucks if resized rods are causing the irregularities... then you get into balancing, etc so you have a decision to make
