-   -   engine oil cooler (https://www.offshoreonly.com/forums/do-yourself-boating-budget/373841-engine-oil-cooler.html)
flashgordon 11-01-2021 11:03 AM
engine oil cooler
looking for suggests on GOOD engine oil cooler. replaced my old ones 3 years, went with MR.COOL 700 cooler,,three years one has failed!!!!!!!!!!!
WTF........
and will be a major job,,,,as it is mounted to the stringer,down below,,in the i cant reach it zone.
i will be mounting new up somewhere.
i have seen photos mounted behind motor.
so any suggestions, who has been a oil longer than 3 years,,,i would never buy anything from MR.COOL again....wont even give a break on new one.
thanks..
underpsi68 11-01-2021 12:13 PM
I bought a MR Cool oil cooler direct replace the for my 8.1/496. Besides the fact that the fitting were in the wrong location, the quality didn't come close to the factory mercury. The cooler was thinner with stamped (thinner)ends in it compared to the cast (thicker) ends on the Merc. I sent it back for a refund and bought the Merc.
resurrected 11-01-2021 12:42 PM
I bought mine from Diamond Performance Parts. Bill was excellent to deal with, I am sure he would be honest on the life expectancy.
fbc25el 11-01-2021 03:57 PM
I got mine from CP PERFORMANCE about 10 years ago. No problems yet.
Rookie 11-01-2021 06:52 PM
I'm sorry to hear this. What failed?
I have mine mounted on the back of the engine on a 2"x4"x12" piece of angled aluminum. Been mounted this way since 2006. I had to notch the bottom around the bell housing. It's bolted to the 2 threaded holes in the bell housing.
https://cimg8.ibsrv.net/gimg/www.off...46d7aba28e.jpg
sailtexas186548 11-01-2021 07:52 PM
I have the Dan Olsen style coolers, you have to control water flow instead of oil to regulate oil temp but I like how compact they are and they don’t require oil lines. Can also disassemble them and clean/rebuilt
flashgordon 11-01-2021 10:02 PM
hello rookie,,
well i guess,,to a certain piont, i am lucky i have closed coolant syste,,or motor would be full of water and oil.
so,,i was going to winterize the fresh water side,,lake water goes to strainer then oil ,,trans coolers then to crank driven water pump then up to heat exchanger then headers,so did the port motor all was good,,then took hose off johnson pump ,,,was loooking for alaittle water to come out,,instead i get about 1/4 cup of engine oil...
i was .........wtf........called mr .cool...said well they are three years old,,,maybe i didnt winterize correct,,honestly i really dont need to winterize anything ,,as boat sits in my insulted heated garage..
i will be mounting them similar to yours rookie,,,first is oil out of boat..but then if i cant get them out ,,buying new one anyways,,,just have to also buy trans cooler..
thanks advice,,,post photo,,i have a starter and remote oil filter to deal with..
thanks again
https://cimg5.ibsrv.net/gimg/www.off...1415bdeac3.jpg
https://cimg0.ibsrv.net/gimg/www.off...98785cdee3.jpg
flashgordon 11-01-2021 10:03 PM
thanks sailtexas,,,never heaqrd of them but like u can control flow to temp up..will check out
thanks
flashgordon 11-01-2021 10:11 PM
yea,,,all they wanted to do was sell me new oil...
will look at merc ones..if i can find..
thanks
sutphen 30 11-01-2021 10:17 PM
same here,,mine were purchased in 2004,,still going,they were the thermosted 1000hp capable ones.
