Cooling system for 500hp Bbc/bravo 1 >
Old 06-06-2022 | 10:25 AM
I'm curious how far below the hull the center of the prop should reside. Yours looks "right" but I know there's a formula, of sorts.
daddio211 is offline
Old 06-06-2022 | 10:50 AM
you can’t afford to run a bravo too high…it’s not a surface drive.
smarter people than me can chime in to tell you the right setup. I just know if you raise it too high…hope you have 3-4 spare drives laying around.
1MOSES1 is offline
Old 06-06-2022 | 11:12 AM
4.7" below
JaniH is offline
Old 06-06-2022 | 11:14 AM
x-dim is cut to 17", as many here recomended.
JaniH is offline
Old 07-09-2022 | 04:42 AM
Wich coolant filler cap i should start with? i have 8.2psi, 10psi, 13psi caps in hand. Cannot find the spec for hp500 cap.
JaniH is offline
Old 01-28-2023 | 07:45 AM
Wich coolant filler cap i should use? i have 8.2psi, 10psi, 13psi caps in hand. Cannot find the spec for fresh water cooled hp500 cap.
JaniH is offline
Old 01-28-2023 | 08:36 AM
I'd use the 13lb one first.will keep boiling down in the heads.
what temp. thermostst?
sutphen 30 is offline
Old 01-28-2023 | 10:27 AM
160F high flow thermostat.
JaniH is offline
