Carb in a box question
Old 06-14-2022 | 10:41 PM
TomZ's Avatar
No telling what that carburetor is. The 80486 doesn’t match anything via search through Holley list numbers. 80486 does come back as a classic series 950 but those carbs have contoured bodies with no choke tower. The baseplate also has a vacuum port for non-ported vacuum advance… should not be there on a marine carb so the baseplate has been changed/bowl vent tubes changed. Who really knows??
Can you get a picture of the baseplate with the numbers on the butterflies?
TomZ is offline
Old 06-15-2022 | 12:04 AM
Originally Posted by Scarab28
I have a complete spare box if you need one. Best carb for that app would be a holley 750. Fuel pump needs to be able to make 6 lbs at idle and 11 lbs when full throttle if making. 5 lbs boost..
great tips thank you all...i've made a top of the box i'm going to try if it works then let you know...realy thankful for advice..tnx
Zole is offline
Old 06-15-2022 | 12:06 AM
i'll get the pic when i finish my yob...SB found a guy that has the same engine so i'll ask him more about the set up...you are all great..thanks so much
Zole is offline
Old 06-15-2022 | 12:08 AM
Originally Posted by Zole
thank you SB realy means a lot...mostly im surfing throu som old posts on forum trying to learn as much as posible...thank you i'll take a look
looks like the same engine...i'll send post to the guy and ask him will he help...hope he is a nice guy...tnx
Zole is offline
