Build engine
Old 07-11-2022 | 09:49 AM
  #91
Did you pull the rest of the plugs out? Ill bet they are all hitting the pistons. If they aren't something bad wrong in that cylinder.
fbc25el is offline
Old 07-11-2022 | 10:05 AM
  #92
Yes i've pull aut all other plugs...Just this one made a mess on cil #6...all other look fine...black but fine.
Zole is offline
Old 07-11-2022 | 10:13 AM
  #93
That plug doesn't look broke from an impact to me.
It looks torched, melted.
cheech is offline
Old 07-11-2022 | 10:23 AM
  #94
Yeaa...the exoust was extreemly hot before that happend..
Zole is offline
Old 07-11-2022 | 10:33 AM
  #95
SB
Did you do compression on all others to see how if, if anything, #6's 120psi is ?
SB is offline
Old 07-11-2022 | 10:40 AM
  #96
No i just tested #6 all other plugs look fine..and when i test #6 it pumps 120 psi in a few sec does not take a lot of time
Zole is offline
Old 07-11-2022 | 10:42 AM
  #97
SB
Do it, just for schits and giggles, and let us know. (See, you get to learn american terms while learning our engines )
SB is offline
Old 07-11-2022 | 10:56 AM
  #98
Ok profesor SB...i'll do that and let you know but i know there will be no change the other 7 cil will have 180 psi for shore...i can hear the cil puff out compresion good...giggles mean laugh and schits i dont know
Zole is offline
Old 07-11-2022 | 11:09 AM
  #99
SB
Pretty much the same as doing something “for the hell (heck) of it.”
SB is offline
Old 07-11-2022 | 11:44 AM
  #100
Ok i'll do it for the hell
Zole is offline
