Build engine
Old 07-14-2022 | 01:27 PM
  #121
Pretty sure that SB said the long reach plug was correct for the 088 head
yea 14 mm he sead...i did not messure.The engine works fine on 7 cil just #6 makes problem..Same spark plugs all oraund.
Zole is offline
  #122
resurrected's Avatar
I run short AC's in my 088 heads.
resurrected is offline
Old 07-14-2022 | 01:32 PM
  #123
What would that be in NGK world..thank you
Zole is offline
Old 07-14-2022 | 01:46 PM
  #124
No he said the ones Zole pictured looked too long. As quoted below.
The MR43T specs are what's called for the 088 heads.
Originally Posted by SB
That spark plug appears to have longer reach than what oe cast iron heads use. (.460”) What heads do you have ?
this is what they should look like with factory cast iron heads:
cheech is offline
Old 07-14-2022 | 01:49 PM
  #125
F-2 Speedy's Avatar
Okay. Oem GenV cast iron rectangular port heads. Should be using a typical .460” reach 14mm thread tapered seat plug.
Being supercharged, i’d run an acdelco mr42t or equivalent.
Possible that those extra long spark plugs you used caused preignition. You could have other tuning issues too, but this is a serious problem.
I miss quoted SB, you should be running the short ones, cheech we were posting at the same time
F-2 Speedy is offline
  #126
Standard and Iridium numbers below.
The actual plug number for each is in the comments.
NOTE: The numbers listed are the OEM heat range.
cheech is offline
Old 07-14-2022 | 02:08 PM
  #127
So this looks a lot shorter...Ok i'll buy this one see the change...Do you all think that the piston could have hit the spark plug...on only one cilindar?
Zole is offline
Old 07-14-2022 | 02:26 PM
  #128
F-2 Speedy's Avatar
did you previously say 180 comp on all cylinders now #6 is 120 ?..........Id run a heat range 7 in the NGK
Old 07-14-2022 | 02:32 PM
  #129
Yes exactly 120#6 now..So like this one on the picture yust #7?
Zole is offline
Old 07-14-2022 | 02:35 PM
  #130
F-2 Speedy's Avatar
personally I wouldn't run it any more, pull the head I think the piston is damaged
