Build engine
Old 07-01-2022 | 09:52 AM
  #51
F-2 Speedy's Avatar
what heat range plugs are those..looks fat to me
F-2 Speedy is online now
Old 07-01-2022 | 09:59 AM
  #52
That was a good comment. Even the threads are almost totally black. I don't think it is pig rich, but the plugs are not getting hot enough to burn off all the deposits. Too cold of a plug is definitely safer than too hot, especially with a blower. I think I would try the same NGK plug but at least one heat range hotter.
kornegle is offline
Old 07-01-2022 | 10:17 AM
  #53
number 6 heat range...
Zole is offline
  #54
so number 7 heat range
Zole is offline
Old 07-01-2022 | 10:32 AM
  #55
F-2 Speedy's Avatar
In the NGK world the lower the # the hotter the plug, 7 is cooler than a 6
Old 07-01-2022 | 10:47 AM
  #56
thease are 6 so i'll need 5...right
Zole is offline
Old 07-01-2022 | 11:38 AM
  #57
SB
Don’t run a 5. Too hot.
A delco r42t or ngk 7 is typically preferred on mild supercharged engines.
You have some tuning issues.
I would do a compression test also, just to make sure nothing sizzled.
Also remember, as pointed out by Arcticfriends too…your ignition is from Procrap. I mean Procomp. Now speed shop inc ir something like that. The cheap of the cheap companies. Not saying it’s an issue now, but it could be. Keep it in back of your mind.
SB is offline
  #58
F-2 Speedy's Avatar
Im not going to advise on that, Im running 7's in my Whipple engines, someone else will chime in
Old 07-01-2022 | 11:48 AM
  #59
ok..i'll buy 7 ngk plugs....i did the compresion test and i have 175 psi on all 8 cilindars..is that god for my set up...
Zole is offline
Old 07-01-2022 | 11:50 AM
  #60
F-2 Speedy's Avatar
yes thats good, God has nothing to do with it.......
