Build engine
Old 07-01-2022 | 12:07 PM
  #61
SB
Unrelated questions:
what prop and size you running ? Grar ratio ? I forget size if your boat ? Current speed at wot ?
SB is offline
Old 07-01-2022 | 12:10 PM
  #62
yes thats good, God has nothing to do with it.......
sory no hard filings i hope yust lack of gramar
Zole is offline
Old 07-01-2022 | 12:12 PM
  #63
prop size 24...bravo 1 stok...cris craft boat...speedometer not working..
Zole is offline
Old 07-01-2022 | 01:19 PM
  #64
F-2 Speedy's Avatar
put a gps mph app on your phone.or kph
F-2 Speedy is offline
Old 07-01-2022 | 01:28 PM
  #65
yeah...i do that but today i had fuel pump problems so i could not do that...i've posted that this morning maybe nobody saw that...runing aut of fuel at wot...
Zole is offline
Old 07-01-2022 | 02:17 PM
  #66
F-2 Speedy's Avatar
Originally Posted by Zole
i run into some problems today....i started loosing throtle after a few minutes of wot...i guess my fuel pump volume is small..is there a mehanical pump with larger wolume of fuel...this is mine
Im not sure on the HP pump maybe SB knows
Old 07-02-2022 | 12:16 PM
  #67
when and if you have the time can you shine a light at my fuel pump problem....thank you in advance
Zole is offline
Old 07-02-2022 | 06:54 PM
  #68
mcollinstn's Avatar
If your fuel pressure remains above "6psi plus BOX PRESSURE" then you're NOT suffering a fuel supply problem.
At WOT (wide open throttle) box pressure and manifold pressure are very close, so you can use that as a reference.
mcollinstn is offline
Old 07-03-2022 | 12:54 AM
  #69
good morning i yust got up.Ok i undersrand my pressure is ok but my volume i what im askung about..It is like this...I run wot for 1 minute and then the engine starts to lose rpm...I lover the trotle to around 2000 rpm wait for some time and then i can run wot again.Is it fuel pump volume small.
Zole is offline
Old 07-03-2022 | 06:20 AM
  #70
SB
Well….I guess you could be correct.
Floats set too low or needle and seats too small could do this also. Ie: keeping good pressure but not enough volume. One would think it would happen faster than a minute, but that’s just thinking.
Be careful running it the way you have (wot rpms falling after a bit) as this can cook things fast.
SB is offline
