Borg/Warner Velvet no reverse? >
Old 05-09-2007 | 07:54 PM
Default Borg/Warner Velvet no reverse?
Been a while since I last used the boat.
I'm able to go forward but not reverse? Transmission does not engage in reverse? Checked the linkage and the control is putting the transmission control in the correct position.
I had the motor pulled and then the transmision. Upon doing so we had transmission fluid dripping from the back seal.
Can anyone recommend a good transmission shop in S. Florida?
Any thoughts?
Thanks in advance..
Beep Beep is offline
Old 05-09-2007 | 07:57 PM
http://www.go-fast.com/
The best.
MILD THUNDER is offline
Old 05-09-2007 | 09:28 PM
ACTIVESHACK's Avatar
You said it was dripping oil. Did you overfill it when you put oil back in ? Never put too much oil in a velvet drive because it will make them slip. Every year when i change it in my Mastercraft i would pump it out with a hand pump and pour 2 qts. back in. Last year i didn't get it all out and it was 1/4" over full and it slipped. I pumped a small cup full out to get it 1/4" below full and it hasn't slipped again.
ACTIVESHACK is offline
Old 05-09-2007 | 11:03 PM
jeff32's Avatar
BAM Marine? they are inflorida I think!
jeff32 is offline
Old 05-10-2007 | 05:05 AM
Mindi
We also have quick turnaround on Transmissions, call and ask for John for more info, he is one of our our Master Techs.
954-237-0332, press "0" and have him paged.
Doller Offshore is offline
Old 05-10-2007 | 06:14 AM
Mbam's Avatar
Offshoreonly Advertiser
Check the oil for metal, the most common failure is exploding the reverse plates radially. Happens from a high RPM shift or too much throttle in reverse. We use a special plate that won't do that. We also add an extra clutch. They stil have limited capacity in reverse, see a few just wear out the frictions backing the boat off the trailer. It's helps a lot make sure the hull is in the water at least a little bit first
Mbam is offline
hydrostreamvector4m
Sonic
1
09-09-2007 06:04 AM
NJgr8ful
13
08-24-2007 09:20 PM
NJgr8ful
08-09-2007 11:02 AM
Horsepower
4
06-12-2004 10:51 AM
Kohldog
4
06-06-2003 02:33 PM
