upside down the drain ? >
Old 05-12-2007 | 09:21 PM
Default upside down the drain ?
This will probably sound like a VERY dumb question but, wheres drain plug on these bravos ? they are supposedly origanal to the boat which would make them 1990 vintage bravo ones ? i hate to have to stand em up upside down everytime i want to change the sauce !! they arent anything fancy (XRs or XZs ) there just isnt a drain plug that i can find anywhere they do have the remote resevour bottles inside the transom HELP !!!!!!!
rumblfish1966 is offline
Old 05-12-2007 | 09:45 PM
I think you have to remove the prop to access the drain.
David Stotz is offline
Old 05-12-2007 | 11:53 PM
Mr Gadgets's Avatar
Charter Member #601
Yeah,
Remove the prop and at the bottom of the hub, below the propshaft will be a drain plug. If there is nothing there, the older ones (88) had a drain in the front of the bullet on the lower part. If someone put a nose cone on.. it may have been covered over...
But pull the prop.. it will be there more than likely..
Hope this helps..
Mr Gadgets is offline
Old 05-13-2007 | 06:20 PM
Default Found !!
thanks gentleman these are the first experience Ive had with bravos (and 502s)
Old 05-13-2007 | 08:58 PM
Mr Gadgets's Avatar
Charter Member #601
YW.. and enjoy, like we all have, the many experiences you will probably have in the future. Welcome to Performance Boating!!
Old 05-13-2007 | 09:11 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
BTW, you fill the drive with lube thru that same behind the prop drain hole. Do not fill it from the top vent screw.
US1 Fountain is offline
Old 05-16-2007 | 02:42 PM
Cool Uh-oh!
If you are asking a question like this I would recommend taking your boat to a certified shop. You will be ahead in the long run. Thanks, Cam-shaft.
Cam-shaft is offline
Old 05-16-2007 | 02:58 PM
camshaft this is why we have these forums to ask ? and learn.nobodys perfect
awsomethunder is offline
Old 05-17-2007 | 07:06 AM
don't forget to change the washer on the drain screw!!
dollerparts is offline
SHARKEY-IMAGES
OPA/The Jersey Boyz
25
09-22-2008 03:24 PM
glassdave
03-10-2004 09:32 AM
Daryl
12
07-08-2003 11:39 AM
CAP071
1
05-02-2002 10:30 PM
