Alpha-1 Impellor Replacement >
Old 05-21-2007 | 08:54 AM
NoQuarter
Default Alpha-1 Impellor Replacement
Worked on an Alpha for the first time this weekend. The impellor is in the lower unit! Wasn't too bad, and turned the project into a complete lower unit service.
It did make me appreciate how simple the Bravos are with the engine mounted impellor, though.
Old 05-21-2007 | 10:15 AM
97BossHammer's Avatar
You mind posting the step by step process? I have a feeling I'm going to need to do it myself here soon..........
97BossHammer is offline
Old 05-21-2007 | 12:03 PM
Registered User
There's not a whole lot to it, kinda self expalnatory once you get into it. Just make sure you put it gear before you split the lower unit and lube the impeller heavily before you put it back in with vaseline or about anything else for that matter.
320es is offline
Old 05-21-2007 | 03:46 PM
Here ya go...
http://www.mercstuff.com/waterpumpinst.htm
Ryan00TJ is offline
ferraristyle
08-15-2005 10:08 PM
Jeff Pierpont
1
03-28-2005 08:30 PM
Hiflier68
8
03-11-2004 12:02 PM
21_senza_383_2
3
03-24-2003 12:04 PM
klmken
3
04-26-2002 08:14 PM
