VI SSM Disassembly >
VI SSM Disassembly
VI SSM Disassembly
Old 07-30-2007 | 02:05 PM
Default VI SSM Disassembly
I cracked the gimbal rings on one of my #6 dry sump drives. I am attempting to take it apart so I can replace it, but I am having trouble removing the pivot pins that hold the trim asssembly in. I have removed the zinks, pulled out the four bolts underneath and tried tapping it out using a slide hammer on the stud in the center. So far, it hasn't budged. I'm afraid to beat on it any harder until I know I'm not going to destroy anything.
Anyone familiar with the problem?
Thanks,
J. Jay Forbes
jjforbes is offline
Old 07-30-2007 | 02:33 PM
cougarman's Avatar
Send me an email and I'll give ya my number and walk ya through it.
Jon
cougarman is offline
Old 07-30-2007 | 03:52 PM
You need a full service for that job. If you don't have all the proper tools, you are going to have a heck of a time getting it apart. And if you damage other parts, it gets very expensive. We are located on the east coast, send it over.
John the Drive Man is offline
Old 08-01-2007 | 06:36 AM
Jon
Cougarman,
Thanks for taking the time to reply. My email addy is j_jayforbes [a-t] compuserve.com
jjforbes is offline
Old 08-03-2007 | 03:43 PM
Those pins can be quite difficult to remove. I have used heat many times with success but if the gimbal ring is cracked your slide hammer can't do it's work because the broken ring is flexing and robbing the energy from slide hammer. A couple of times I have had to drill the bottom of the boss to split it and release pin. Not knowing your skill level or shop I must say, no offense but it may be a job for a shop. The retaining pin for the lower swivel pin is easy to break. The upper swivel pin is also easily damaged and very expensive. Hope your outer transom plate is okay. I can really appreciate a guy williing to work on his own boat. Good luck to you.
rhinoLX is offline
Run_em_hard
Drives and Lower Units
7
02-22-2008 08:22 PM
cloudmaster_321
9
07-09-2007 06:31 PM
Deltarat
Fountain
12
03-31-2006 03:53 PM
Deltarat
6
03-02-2006 11:12 AM
Viper31
0
10-08-2004 05:19 PM
