No Shift?
Old 08-15-2007 | 03:41 PM
Default No Shift?
Hello, I have a Scarab with 454's and trs drive. The other day when i was docking, the port side engine would no go into reverse. It would go into neutral and foward, but when the trottle was pulled back to reverse, nothing would happen.
There was no clunking, or anything of that nature...I though the cable mught be shot, but when it was shifted the cable moves in full rotation on the transmission.
Why would it go into forward and netreul, but won;t engage in reverse??
Seguin33 is offline
Old 08-15-2007 | 05:36 PM
Different clutches for reverse. Sounds like you may need to pull it. Reverse isn't as tough as forward. Check fluid, find a trannie guy.
Jim
MOBILEMERCMAN is offline
Old 08-16-2007 | 08:41 PM
There aren't any noises of any kind..jsut doesn't engage.
Seguin33 is offline
Old 08-16-2007 | 09:54 PM
Has the linkage been checked for correct adjustment?
Darrell.
DMOORE is offline
Old 08-16-2007 | 10:39 PM
If its a borg warner, you can disconnect the cable at the trans. The linkage on the trans has detents f-n-r. You can try to see if cable matches the detent in reverse. Good luck.
Jim
Mkeller
12
06-27-2006 08:44 AM
HiPerf2000
Sonic
2
04-22-2004 08:06 AM
Luvoffshore
4
03-24-2003 05:39 PM
