Who builds the strongest XR >
Old 10-12-2007, 07:00 AM
thunderusone's Avatar
I have thier top caps and they are Huge to say the least. I would recommend them to be the best in the market. 1200hp on the other hand is absurd. Until someone comes out with better gears.....none of them are better than the other if properly set up. Get an imco lower with torsional shafts, put in a max upper vertical, change to good bearings and you are good to go. Blue print the case, debur everything, and set the gears up to hit the middle of the merc recommended specs and be easy on the sticks!
thunderusone is offline
Old 10-12-2007, 07:02 AM
Oh, and if you do replace your top cap....shim it spec!! Big mistake most people make is just slapping on a top cap!
Old 10-12-2007, 09:14 AM
Charter Member #601
Mr Gadgets's Avatar
GPM,
what kind of power are you running these days??
Mr Gadgets is offline
Old 10-12-2007, 03:17 PM
GPM
Originally Posted by Mr Gadgets
GPM,
Way to much for an XR, a bit over 14.
GPM is offline
Old 10-12-2007, 05:05 PM
Smitty's Avatar
I'm confused ??? If you know you have more power than an XR can handle, why ask who builds the best one??
Smitty is offline
Old 10-12-2007, 10:24 PM
GPM
The boat's to small for a 6, what other options are there? the best one may last more than a couple of hours.
GPM is offline
Old 10-13-2007, 12:46 AM
GPM,
What size is the boat? There are quite a few smaller cats and tunnels that have run a #6 with some very good results. Seriously 1200HP will just kill a bravo.
Darrell.
DMOORE is offline
Old 10-13-2007, 06:05 PM
GPM
26, I was told by the manufacturer it wasn't a good idea, doesn't mean I haven't thought about it.
GPM is offline
Old 10-13-2007, 09:27 PM
SeaRay Sundancer
tblrklakemo's Avatar
here is 26 with a quad rotor 540 and a #6 119MPH. Guy is turbo666 your crazy not to run a drive like a 6.
tblrklakemo is offline
Old 10-13-2007, 10:45 PM
26 is plenty big for a #6. Check out hotboat.com, there are a number of cats in your range running #6 drives. 1200 HP and a 6 in your boat ,should put you well into the 130's.
Darrell.
DMOORE is offline
Quick Reply: Who builds the strongest XR
