Bravo XR Maintenance >
Old 05-02-2008 | 04:47 AM
Default Bravo XR Maintenance
What are the maintenance and service requirements for the Bravo XR ?
- Lube every 50 hours ?
- Gimbal Bearing Greasing ?
- U-joint ?
- U-joint shaft ?
Does the drive have to come off every 50 hours ? Or is 100-150 hours doable ?
How long do you guys really run without taking the drive off ?
What can be done with the drive on ?
What has to be done with the drive off ?
As you can see, I want to remove the drive as little as possible....
intouch1 is offline
Old 05-02-2008 | 08:52 AM
Downtown42's Avatar
I change lube at 25.... and pull drives at 50 or every year.
Downtown42 is offline
Old 05-02-2008 | 12:20 PM
The U-Joints don't require grease (sealed, at least on mine). You should do the drive oil at 50 hours or once a year and pull the drive to grease the drive splines every season. Good time to inspect bearing, bellows, zincs, etc.
techman is offline
bert4332
10-17-2008 02:46 PM
Son of a Gun
1
06-19-2006 09:22 AM
fatdaddy
03-05-2005 08:33 AM
cloudmaster_321
7
07-06-2004 02:52 PM
maverick1
12-18-2002 04:39 PM
