-   -   Dry Sump Bravos (https://www.offshoreonly.com/forums/drives-lower-units/186594-dry-sump-bravos.html)
CIG3 05-13-2008 02:31 PM
Dry Sump Bravos
I saw a thread in the Pantera forum with photos of a bravo that was converted to dry sump. XR upper with imco lower. The drive had a DPM decal on the side. Any info????
Mange 05-13-2008 03:17 PM
It's not dry sump. It's conected to an oilcooler with an oilfilter and oilpump.
I'll tell Tomas to explain more!
Mange
tomas_wallin 05-13-2008 03:51 PM
You do know it's perfectly legal to post in the Pantera forum even if you own a Cig right?! :D
The DPM stands for Dick's Performance Marine and is operated by Mr Dick Tryce aka Mr Gadgets here on OSO.
The idea of the drive is to circulate the oil in the upper. The pump sucks the oil from the lower fitting and sprays it back in the top. I will use a 12x2" oil cooler and an oil filter to keep the oil clean of metal particles.
Mr Gadgets 05-13-2008 09:28 PM
Looks like the story is out.. :) Thank You Tomas for the plug. The oil is actually taken from the lower and is returned to the teeth on the pinion gear in the upper, to help lube and cool the gears.
Dick
Elite Marine 05-13-2008 09:37 PM
No its not!
Elite Marine 05-13-2008 09:39 PM
Hey Dick -
Great idea. I assume youve been getting some great life out of gears with this set up.
When you get a chance, email me at:
[email protected]
I'd like to ask you a few things.
Thank you,
Kirk
tomas_wallin 05-14-2008 02:59 AM
Dick
Yes of course it is!:p :D My mistake!
CIG3 05-14-2008 04:49 PM
Thanks guys. My first boat was a 24 Pantera. I really like the idea.
Blue242 05-14-2008 05:40 PM
My IMCO Extreme SC has been plumbed that way for a while.... ;)
Mr Gadgets 05-14-2008 11:11 PM
Blue,
Are you using a similar input and output arrangement?
