outdrive problem?
Old 08-31-2008 | 04:46 AM
Question outdrive problem?
I have a bravo 1. The boat was running good when it suddenly started to slip at first I thought cavitation. But after shutting down it does it when ever I start giving it some gas. There is no noise I can hear from the out drive over the engine. I was able to idle back in.
code blue is offline
Old 08-31-2008 | 10:56 AM
Good chance its the coupler.
RBeyer is offline
Old 08-31-2008 | 11:10 AM
HiPerf2000's Avatar
i agree
HiPerf2000 is offline
Old 09-02-2008 | 09:39 AM
Mr Gadgets's Avatar
Charter Member #601
One thing to check is open the hatch and have someone watch when you put it in gear.. see if the shaft speeds up when you rev it up.. careful you dont dump them into the bilge!! One thing you might check is to see if you have a plastic hub in the prop.. I rememeber when they had them, the hub would spin, but would hold enough to let you idle back in.. Something to check, hoping it is not the coupler..
Hope this helps.
Dick
Mr Gadgets is offline
Old 09-04-2008 | 08:25 PM
Could be the cone clutch
tripple digits is offline
Old 09-17-2008 | 08:59 PM
Default Thanks
Thanks everyone for the input. Sorry I didn't get back sooner my computer screen on a 6 year old laptop burned out.
As for the boat I'm glad to say it was only the prop. I spun the hub. Older rubber style. $89 installed in the prop works fine now.
East Coast B
5
02-11-2007 05:31 PM
gripit
5
05-02-2006 12:21 PM
Scarab28
5
07-18-2005 07:47 AM
fastfred252
18
06-28-2005 06:36 AM
timucin
25
12-05-2003 12:00 AM
