Bravo Gear Ratio?
Old 12-21-2008 | 02:21 PM
Default Bravo Gear Ratio?
What is the easiest way to check the gear ratio of a Bravo Drive?
stormbauer is offline
Old 12-23-2008 | 07:25 PM
Mr Gadgets's Avatar
Charter Member #601
The old fashion way.. mark the propshaft and turn the input shaft. But you better do it a couple of times. The difference between 1.36 and 1.5, is kind a close.
The other way is to count teeth, but you need to see the lower and upper gears to do it.
Hope this helps.
Dick
Mr Gadgets is offline
Old 01-15-2009 | 03:22 PM
I can run a serial number for you if you have it. shoot me a call 856 232 6969
NuWaveparts.com is offline
Old 01-15-2009 | 03:56 PM
Big Time's Avatar
Mine has it posted right on the outdrive....might be worth a shot to take a good hard look
Big Time is offline
AXION
Sonic
5
06-16-2021 07:07 PM
40hustler
Drives and Lower Units
5
05-29-2007 11:55 PM
MacGyver
Prop Talk
1
11-03-2006 06:38 PM
Notched_Baja
6
04-09-2004 09:12 AM
Interceptor
4
03-20-2003 06:49 AM
