TRS Drive Oil
Old 05-13-2009 | 03:29 PM
BDiggity's Avatar
Default TRS Drive Oil
Going to replace the oil in my drives. I am using Valvoline Syn Racing oil in the engines & thought about using their High Perf 80w-90 or SynPower 75w-90 gear oil in the drives. Thoughts on either of these two or other suggestions?
Also how much is needed for a pair?
BDiggity is offline
Old 05-13-2009 | 04:08 PM
Ive always used mobil 1 75-90, royal purple 75-90, or amsoil 75-90. You'll need 8 quarts to do both drives.
MILD THUNDER is offline
Old 05-14-2009 | 12:21 PM
Isn't the Mercury blue lube what you want to use?
Wannabe
wannabe is offline
Old 05-15-2009 | 06:31 AM
BDiggity's Avatar
Wannabe
i dont know, ive never used merc stuff.
BDiggity is offline
Old 05-15-2009 | 09:32 AM
use anything but royal purple merc has tested thaqt stuff and is bad ist hand knowlege here todd
jennys express is offline
Old 05-17-2009 | 03:54 PM
Default Yup
USE THE BLUE. It's freaking high dollar, but it works. Bout $11 per quart at the store, u need 4 quarts. Essentially, it's like 75-80 wt gear oil, but don't use synthetic.
Yellow_ICC_OK is offline
Old 05-17-2009 | 04:43 PM
You talkin about the Merc High Performance (blue) Gear Lube?That's cheap! It's $16 a quart around St.Louis area!!
picklenjim is offline
Old 05-17-2009 | 05:27 PM
I just changed over to the Merc Hi-perf gear oil (blue in color) in my TRS drive. It took about 3qts and then I had to buy a 4th quart to top of the drive and fill the over flow tank.
crapr6 is offline
Old 05-17-2009 | 06:17 PM
The guy at the Merc dealer told me that when the oil prices went up to over $100 dollars a barrel Merc raised it.Then when it went back down they didn't!!
Old 05-29-2009 | 09:10 PM
Hang Time 27's Avatar
You would believe what merc says about another drive oil, when they are trying to sell thier own??
Hang Time 27 is offline
