Kaamma drive know how >
Old 02-02-2010 | 10:17 PM
sac
I also had a mold made to produce the rubber boots if anyone needs them for the Kaama drives
sac is offline
Old 02-06-2010 | 08:32 AM
Hi,sac!
So how did your boots fit ,like the originals. And how much for one? I'm sure there will be quite a few kaama owners asking.
Thanks...Jim
kaamaman is offline
Old 02-06-2010 | 03:05 PM
sac
The fit was good,had the boat stored in the sun,they weather cracked so I will have to change the rubber type,they only lasted two years
sac is offline
Old 02-07-2010 | 07:10 PM
How many boots did you have made? I am thinking of having a mold made because I have one bad that has a pin hole leak in it that will probably get worse. Finding someone to run the mold and make the parts is my hold up, having the mold made is the easy part for me.
showtime83 is offline
Old 02-08-2010 | 04:03 PM
sac
I had two made and will need to make some more,any ideas on the rubber type, the originals lasted 15 years
sac is offline
Old 03-13-2010 | 09:19 PM
bck's Avatar
bck
Charter Member#568
What happened with the boots?
Straight bottoms and flat decks
bck is offline
Old 05-04-2010 | 11:52 PM
Ok after a little warmth I am able to staighten this out a bit.
I believe the drive are underdriven at 1: 1.25 approx. 8% right?
Inner shaft turns 1.25 rev when the prop turns once.
The stamping on the props indicate 34 pitchX 18'' Tach was below 4000 at 80mph approx.
They are not counter rotating but do spin clockwise and counter clockwise.
I found faulty tachs among other problems. I will post up some new speed / rpms asap if it doesnt rain tomorrow.
kneeslider74 is offline
Old 05-05-2010 | 09:12 AM
KNEESLIDER,are you in illinois,did you buy the boat from a guy named jay,if so i know a lot of history on the boat.
mike tkach is offline
Old 05-05-2010 | 09:07 PM
Default Fixx
Originally Posted by BOATMAN302
I cant understand what 23 outer 35 inner//// and 26 outer and 35 inner means where are you getting these # from. If you turn the h bar on the inside of the boat by the u joints how many revolutions is the prop turning. If you have someone look inside at the h bar while you turn the prop that will give you an indication of your gear ratio. eg. 8%. 13% 18% overdrive or underdrive Bruce
35/23 gears =1.52 ratio
35/26 gears = 1.34 ratio
i have seen guys cut up truck inner tubes and use them for the outside boot's..it worked really well!
FIXX is offline
Old 05-05-2010 | 11:33 PM
No sorry from WI. I bought from Jarrod, could be the same guy though. He was from quad cities,,, in davenport I think.
I am going through it now and trying to get'er settled. Got her up to 80+ but WOW it porpuses bad at that speed. I found a crack in one of the props and am in need of some help, sure would think that upper 90's should be attainable.
You?
