TRS Shorter Lower
Old 10-20-2009 | 03:06 PM
Default TRS Shorter Lower
I feel pretty silly asking this....... but do they make a short lower for TRS drives??
areyouliving is offline
Old 10-20-2009 | 03:35 PM
fireboatpilot's Avatar
RIPSTA Racing Team
I'm not 100% sure but there are sprotsmaster lowers for the TRS drives which where called #2's I'm not sure if they made a shorty in the sportsmaster series. Not an answer for you but should give you a direction to look.
fireboatpilot is offline
Old 10-20-2009 | 05:04 PM
The SSM#2's were actually deeper than the TRS in order to run larger props.
I know it's the wrong way but, it you want to go deeper, I have a TRS 2" spacer thats taking up space in my garage.
Holy Smokes is offline
Old 10-20-2009 | 06:20 PM
c_deezy's Avatar
Yep. Its called a Konrad
c_deezy is offline
Old 10-20-2009 | 06:43 PM
rws's Avatar
rws
They actually made a shorter upper called a KT I have only ever seen two and one was on a boat in a picture. A guy named Ron from western Pa that was on oso back in the begining had one.
rws is offline
Old 10-21-2009 | 07:35 AM
Audiofn's Avatar
Charter Member #232
Yup with the Konrad you can go either 1 and 3/4 shorter or I think they even make a drive that is 2" shorter then that.
Put your best foot forward!
Audiofn is offline
Old 10-27-2009 | 11:51 AM
Thanks for the replies, It seems like my props set really deep compared to others. I see all these different lowers being talked about s&m 3's and 2's and didn't know if any of them were on TRS drives.
The Konrads replace the whole drive right?
Old 10-27-2009 | 11:59 AM
Biggus's Avatar
Yes, the Konrad drive is a direct replacement for the TRS. The standard Konrad lower is 1.7" shorter than the TRS
The Konrad shorty (X-Factor) is another 1.7" shorter than the standard Konrad lower.
If you were incredibly deep, we could raise the propshaft by 3.4" with the optional X-Factor lower.
Feel free to give me a call, I'm the Konrad factory rep.
Kurt 715-410-0735
Biggus is offline
