..."off the wall".. drive question. >
Old 04-09-2010 | 12:00 AM
Default ..."off the wall".. drive question.
I am in the process of piecing together a "new" project boat...
The hull is a 1979 Excalibur 24.
It originally had a TRS drive with a Merctrans transmission...
I am in the process of building the engine which consists of a 540 with an M3 procharger..
I would think a conservetive hp estimate would be in the 800+ range...
I NOW am trying to figure out what to use for a drive without breaking the bank (the engine has aleady acomplished that)
I remember reading a while back that Imco ran a big single engine with a splitter box and two of their drives...
What do you think would happen if I did about the same thing but used Alpha drives??
I'm sure I could "gear up" the splitter box to limit the prop size to 21-23 pitch..
Would I just blow them up two at a time or would it handle the power??
Thanks,
Doug
Boatally Insane is offline
Old 04-09-2010 | 12:27 AM
How are you going to shift it? the alpha uses a momentary ign kill to shift. A 330 hp 454 can also do a remarkable job at preparing an alpha for a rebuild too.
phragle is offline
Old 04-09-2010 | 01:26 AM
No way I would do a splitter to Alphas. Thats like saying 2 Chevettes are as good as one Corvette.
Griff is offline
Old 04-09-2010 | 04:32 AM
You could buy a good used SSMIII or V for the price of a splitter box.
rdoactive is offline
Old 04-09-2010 | 12:03 PM
I would go with a Konrad.
Griff is offline
Old 04-09-2010 | 01:06 PM
Arneson on craigslist in NJ $2500.00
ken sampson is offline
Old 04-14-2010 | 08:26 AM
MOP
The TRS with a BAM tranny would have held up, not much else lasts to long under 900hp. Only Arneson and Konrad!
Phil
MOP is offline
Old 04-14-2010 | 02:58 PM
Brad Zastrow's Avatar
Upgrade the transmission for sure. Stock trans will not make it on that power. TRS could be made to live if careful. Two Alphas no chance. I would look for a used Number Five or Wet sump Six.
Brad Zastrow is offline
