Alpha One Gen 2 Fluid Level >
Old 05-26-2010 | 11:00 PM
Default Alpha One Gen 2 Fluid Level
Just changed the impeller by dropping the lower only and refilled the gear lube from the bottom using the Merc. pump. It would only take 1 quart, shouldn't it take 2? The dipstick on top shows full but I'm a little confused. Help?
hopper75 is offline
Old 05-27-2010 | 08:09 AM
CIG3's Avatar
Should take a quart and 4-6 onces. Pull the side vent plug in the upper housing and fill unti lit starts coming out with the drive level. Then check the stick.
CIG3 is offline
Old 05-27-2010 | 12:11 PM
I got a couple pumps into the second quart and it came out of the vent hole, I just wanted to be sure there was enough fluid in there.
hopper75 is offline
