side by side #6 drive height??? >
Old 10-14-2010 | 12:24 PM
OldSchool's Avatar
I can use a straight edge and get an exact measurement for you this weekend, but I think that mine are within a half inch of being even with the running surface at neutral trim. 1988 Cig Top Gun with a notched transom. No issues whatsoever getting on plane
Craig
Attached Thumbnails side by side #6 drive height???-solomons2010helo4propshot.jpg
OldSchool is offline
Old 10-14-2010 | 03:21 PM
but your sixes with a notched transom are way further back from the running surface than my 4's on boxes without a notch
302Sport is offline
Old 10-14-2010 | 06:48 PM
OldSchool's Avatar
Chit, my bad. I thought that you said notched. Sorry about that.
Old 10-16-2010 | 11:14 AM
Craig:
Where are your drives at? I'm curious as I raised mine a few years ago to nearly even, but may lower back down one inch for more bow lift at cruising speed. Also, are those water pickups under the hull?
Steve
CignificantOther is offline
Old 10-22-2010 | 01:43 PM
OldSchool's Avatar
Originally Posted by CignificantOther
Craig:
Steve
Finally got down to the boat with a straightedge the other night. My drives are 1" above the hull.
Those are water pickups under the hull.
Old 10-22-2010 | 02:28 PM
That is an aggressive "x" for a flat bottom Cigarette. These are just pleasure boats........right?
