side by side #6 drive height??? >
Old 09-15-2010 | 05:21 PM
Default side by side #6 drive height???
what drive heights have yall seen in a side by side #6 set up. Prop shaft location to the running surface???????
302Sport is offline
Old 09-27-2010 | 03:16 PM
Depends on the hull/weight/hp. Stepped or non-step? Notched transom etc.??? What is your application?
CignificantOther is offline
Old 09-27-2010 | 03:34 PM
non stepped, no notch.......
302Sport is offline
Old 09-28-2010 | 10:25 PM
How much does the boat weigh?
BenPerfected is offline
Old 09-29-2010 | 07:12 AM
around 5400-6400lbs.....
302Sport is offline
Old 09-29-2010 | 11:11 AM
u r thinking of putting 6's on the 33? it already has 4's what real benefit are you going to see? You don't think it might be too stern heavy then?
Good luck with the project.
delsol is offline
Old 09-29-2010 | 02:33 PM
not putting 6's on, i want to see what a straight v bottom with side by side 6's runs for a drive height. 4's are surfacing drives and can go just as high as a 6.
302Sport is offline
Old 10-05-2010 | 06:49 AM
hangem out 2dry's Avatar
are your 4,s on boxes? A #4 on stellings boxes come out to the same dimension as a #6 length and height. the stellings are a little longer than the merc boxes.
hangem out 2dry is offline
Old 10-05-2010 | 01:39 PM
yeah they are on merc boxes.........
302Sport is offline
Old 10-14-2010 | 11:20 AM
Hard to say without a notched transom..........guessing 1.5 to 1.75 inches below hull. That is if the bow is light, go approx 1 inch deeper if you need bow lift.
With a notched transom on a 11,000+ # V hull, .125 inches below the hull works just fine for top end. Also, I think the No. 6 trims in much further than the No. 4 for planing, so no problems with high drive heights.
