Installing Bravo Drive
Noles the input shaft to the drive (big thing with ujoints on it) has to be turning when you shift a Bravo drive, or it may not shift, depending on the position of the brass bump rings inside. I use a pair of vice grips with a finish nail. It will fit in the slot and the linkage should pop out when the input shaft is turning. If it doesnt you may need to take the back cap off and check the detent ball and spring. They will come apart and prevent shiftining.. Remember to drain the drive down some before you pull the back cap..
Hope that helps.
Dick
Hope that helps.
Dick
