powder coating  out drives? >
Old 04-24-2011 | 07:55 PM
26sonic's Avatar
Default powder coating out drives?
has anyone doe this ? and how is it holding up?
26sonic is offline
Old 04-25-2011 | 07:58 AM
Prime and paint. I had a set powder coated, the coating would peel off down to the primer.
Harvey is offline
Old 04-25-2011 | 08:00 AM
might want to try using a different powder coater next time
Old 04-25-2011 | 10:11 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It's been discussed on here before. General concensus is it works, but you need to empty the drive before PC'ing & baking it.
I prefer paint. I had mine done at the local body shop and they turned out fantastic.
Sydwayz is offline
Old 04-25-2011 | 08:45 PM
26sonic's Avatar
brian do you think they hold up better than paint ?
26sonic is offline
Old 04-25-2011 | 09:02 PM
Mine were painted when I got the boat and have held up just fine... plus, they're easy to touch up when needed. Good luck either way.
Shallow Minded is offline
Old 04-25-2011 | 09:14 PM
offthefront's Avatar
paint ......I had some PC and any corrosion will continue .. gassing ....paint is best
offthefront is offline
Old 04-25-2011 | 09:27 PM
bzsmarina
i do powder coating. i have never done my drive cause of having to tear it down. but have done my transom housing and anything i could. holds
up great. been on for years
Old 04-26-2011 | 07:07 AM
26sonic's Avatar
what kind of durable paint would you recommend? if done by a body shop.
26sonic is offline
