What Drive?
Old 09-05-2011 | 09:07 PM
  #131
Default Yes
Originally Posted by A.O. Razor
kjm5125. Have you had any time to get the tranny fixed and the boat in the water?
I had time for a run Saturday, (Sunday prior commitment and Monday crappy weather)
and the main issue was how to get the boat on plane. Arneson surface drives are very different compared to my Bravo Xr's / Shorties. What you need to do is keep the tabs down and stay on the throttles until the boat starts to plane and then she blasts off. Every adjustment you make with the drives and tabs is highly accentuated when compared to the XR's. I definitely need some seat time to fully understand the handling characteristics.
Next time out pictures and or video.
kjm5125 is offline
Old 09-06-2011 | 05:52 AM
  #132
Sounds like things are moving in the right direction. What is the rake on the props?
How is the handling when on plane and at the docks?
Looing forward to hear some numbers.
Congratz on your first succesful outing.
A.O. Razor is offline
Old 09-06-2011 | 08:23 AM
  #133
VIDEO!!! If I remember, you are trying 5 blade 17" Diameter 31 Pitch Props. Can't wait to see what RPM you are running at WOT......also speed.
UrbanDisturbance is offline
Old 09-06-2011 | 07:51 PM
  #134
Rake is 18 degrees
Handling will not be a problem. The line does need to be bled. I'm going to add another pump and reservoir.
Performance numbers to come.
kjm5125 is offline
Old 09-06-2011 | 07:55 PM
  #135
At 4500 rpm's the ROOSTER was pretty amazing. I was not paying that much to speed, as I was concentrating on trim and tab setting.
kjm5125 is offline
Old 09-06-2011 | 08:55 PM
  #136
How would an Arenson work in a single drive v?
skav is offline
Old 09-07-2011 | 11:18 AM
  #137
Give Rik @ Arneson a shout. He can tell you the pros and cons of your particular installation. He's also on the board.
Old 09-13-2011 | 08:27 AM
  #138
Well, when is your next run. We are waiting on pictures and video.... Can't wait...
Old 09-14-2011 | 08:35 PM
  #139
Try again this weekend. I'm am having steering issues and I have ordered a larger reservoir.
kjm5125 is offline
Old 09-15-2011 | 11:53 PM
  #140
Thanks for all the updates. I am surprised there has been problems so far but am hoping they are all worth it! The other formula like yours seems to love the bravo to arneson conversion ( http://www.youtube.com/watch?v=bxjsIl3F3x8 ) Seems like it would have been easier for you since it has already been done on the exact same boat!
Looking forward to updates soon!!!
offshorexcursion is offline
