What Drive?
Old 08-26-2011 | 12:04 AM
  #121
Originally Posted by A.O. Razor
It does. It is included in the ASD#6 and ASD#7M kits. It sits in the standoff box, so you don't have to move your engine forward. One of the many reasons why the setup is as strong as it is. I think it's a Velvet Drive trans of some sort.
Thats what I thought so why is he pulling the motors?
ICDEDPPL is offline
Old 08-26-2011 | 07:04 AM
  #122
I may be wrong, but I think that the backing plate of the standoff box on the Arneson Drive that is inside the engine room and Transmission serve as the rear engine mount when put together. I read the instructions Rik gave me on how to install the ASD7M, and I think that is the way it is set up. There were no pictures as I hoped, so I am a little confused on how to install the drive myself. I may be wrong. At least I hope I am.... Maybe Rik will join this conversation and clarify it.
UrbanDisturbance is offline
Old 08-26-2011 | 12:15 PM
  #123
Originally Posted by offshorexcursion
That sucks you had to move the engines because I heard from Rik that I would not have to. But obviously every boat is different.
Did you have to move them because your notched transom or something else?
No the notch was not an issue.
Installed the drives and engines and bolted everything together. The mounts were 3" apart. They only thing to do was to slide the engines forward.
The transmission is mostly in the bilge and is flush with the exterior portion of the transom. When you take off the access panel that is on the standoff box, you can see the front of the transmission at the transom and the drive shaft.
kjm5125 is offline
Old 08-26-2011 | 12:20 PM
  #124
You are correct and as previously stated, every boat is different, and on some boats you might not have to move the mounts.
kjm5125 is offline
Old 08-29-2011 | 01:54 PM
  #125
Do you think you will have your boat in the water for Labor Day for test number TWO?
Old 08-29-2011 | 08:48 PM
  #126
If everything goes as planned, I'm hoping for this Thursday.
kjm5125 is offline
Old 08-30-2011 | 06:58 AM
  #127
Good Luck. Don't forget your GoPro. I am curious how hard it is to get on plane. I bet it is going to be tricky, but you should figure it out. Personally, I would try getting on plane with tabs and drives all the way down, then slowly raise the tabs after you gain some speed. That is what I had to do when I had blowouts with clever style hydromotive 4 blade props on a bravo drive, 12,500lb 38 foot Cigarette Top Gun. It allowed me to get on plane and keep the RPM's under 3000 when my engines where still a little cold. Just an idea!
Old 08-31-2011 | 05:49 AM
  #128
Good luck with it tomorrow. Looking forward to hear and see how it works out.
A.O. Razor is offline
Old 09-01-2011 | 08:07 AM
  #129
4bus is offline
Old 09-05-2011 | 08:23 PM
  #130
kjm5125. Have you had any time to get the tranny fixed and the boat in the water?
