Imco SCX Set Up
Old 05-26-2011 | 01:24 PM
Originally Posted by SkiDoc
Steve,
I would say yes to this at this point. My tunnel tab is able to take it away. I'm going to try some 16 x 40 x 21 props which should remove some of it. Sonny is using herings which are cleavers with good charcteristics.
Thanks! Keep me posted.
Steve
smiklos@sunprint is offline
Old 05-26-2011 | 06:17 PM
I found some used sct lowers with the number 6 shafts so I needed to change them to scx vertical shafts to get them to fit the scx upper.
SkiDoc is offline
Old 06-11-2011 | 07:40 AM
Any updates?
Steve
Old 06-12-2011 | 06:48 AM
We went out on Friday for final calibration of the engines ecm's. We calibrated for about 2 hours. Eddie got the engines perfected. Idle at 825 and shift in and out with the 6 props well. The lake was completely flat but the set up seemed to work very well. The boat comes on plane well. Turns better. Stays on plane at a very slow speed. All hop could be eliminated with tab. Could blast right past hop with acceleration. Everything feels very smooth, no vibrations, I think the props will do. I was unable to find any smaller diameter props to test. The set up, all in all, seems better than the Bravo set up. One of the SCX drives coming off the trailer would delay shifting going into reverse. We took it off and it will go to Imco tomorrow. I want to make sure it's right. I am very pleased about the set up.
SkiDoc is offline
Old 06-12-2011 | 05:51 PM
Great!
Steve
Old 06-13-2011 | 12:16 AM
Mr Gadgets's Avatar
Charter Member #601
Glad to hear it is working out for you!!
Mr Gadgets is offline
Old 06-13-2011 | 10:00 AM
CB-BLR's Avatar
Chris
Great info!
Thanks for sharing
Chris
CB-BLR is offline
Old 06-14-2011 | 09:29 PM
will the scx fit on the xr gimble.Is the xr gimble strong as the
imco gimble.
fuelcustoms is offline
Old 06-14-2011 | 09:36 PM
2112's Avatar
imco gimble.
I was wondering the same about the ITS gimbal.
2112 is offline
Old 06-15-2011 | 05:06 AM
The SCX requires helmet change but the helmet will fit the XR gimbal ring. I highly recommend the IMCO ring as it is much stronger than the XR. It doesn't really make sense to not make this piece as strong as possible for safety's sake.
SkiDoc is offline
