TRS spins in neutral???
Coming back from PIB my port motor rev'd higher then the starboard as I was trying to get on plane, it felt as if the tranny was slipping. When I got home there was hardly any fluid in tranny so I figured the lack of fluid was causing the slip. I added fluid and made sure I was full of drive oil too. I also Checked the prop hub to make sure I didn't spin it. I didn't hit anything but I figured Id check it anyway.
When the motor fired up the prop started to spin on it's own, as if it was in gear at it's slowest speed. When I piut it in gear it went faster. When I put it in reverse it got ugly. Started making a clanking noise. My gf thinks it's the prop making the noise so I thought maybe I didn't put it back on right. I myself think the noise was coming from the tranny. Hard to say cause I was in the boat she was behind in the driveway. I did over fill the the tranny so I sucked some of it out and redid the prop but haven't fired it up. I was tired and frustrated. Any thoughts? |
Sounds like you cooked the trans...
If it was low on fluid and slipping my guess is you fried/melted the clutches. TRS will sometimes spin very slowly in neutral when on the trailer, but they should not spin very fast. Time to pull the trans and go through it. :( |
Originally Posted by RT930turbo
(Post 3466801)
If it was low on fluid and slipping my guess is you fried/melted the clutches. Time to pull the trans and go through it. :( |
When you say slow how slow. This turns about one turn every second. Should I go ahead and look for a new trans. Any ideas where.
I guess I should of checked the level each time I used it but who would of thought a surveyor would of missed a leaky trans and you would think that the owner would have gave me a heads up, but then again I probably would not have bought it. |
When you tried to put the boat in reverse, did you wait for the prop to slow again before you shifted?
Was your drive in the "trailer" position? Maybe you will get lucky and the noise you heard was your U-Joints clattering if you had the drive all the way up. I seriously doubt your trans escaped damage, but it can't hurt to fill it up with fluid and see what happens. If it was slipping for more than a few seconds, I'm sure it overheated the clutches. |
Clutches cannot tolerate low/too hot fluid. Don't bother taking back to lake, it needs to come out.
Drives aren't in trailer mode. Indicators show them a 9. The prop never stopped in neutral just kept spinning. I put it in forward then neutral, waited a couple of seconds then reverse then back to neutral. This would prob explain why it's harder to spin the prop by hand, I'm turning the trans too? So would using the boat with just forward be a bad idea?
I was told that the velvet trans can be rebuilt does anyone know if the motor has to be pulled or just the drive? |
Originally Posted by s022mag
(Post 3466927)
I was told that the velvet trans can be rebuilt does anyone know if the motor has to be pulled or just the drive? Unfortunately the engine has to come out to get the trans unbolted. You may have enough room to slide the motor forward enough to unbolt it, but in my opinion it's just easier to pull the whole assembly. It's not the endo of the world, and the parts are not brutally expensive. Good luck! |
Call Eric Lavene at Fantastic Finish Marine,in Medina Ohio
330-273-8291 cell # 330-322-8817 He is the Best around, quick turn around,great pricing, if you trailer he can pull it too! tell him I gave you his #'s Dave McGinty! :drink: |
| All times are GMT -5. The time now is 06:08 PM. |
