Dry Sumping Volvo DPR'S >
Old 05-18-2014 | 07:33 AM
  #141
Thanks rickg 1984 & knot 4 me
The nice weather has enabled me to make lots more progress, finished of all the custom Volvo looms and garmin systems and we were able to switch it on and give it a try, everything configured beautifully so next weekend i should be able to flash the motors up. Also mocked up the cylinders for the carbon fibre trim tabs so we can now mould the re-inforecment all coming together nicely:hugegrin::hugegrin:
Peter
Attached Thumbnails Dry Sumping Volvo DPR'S-img_1233.jpg   Dry Sumping Volvo DPR'S-img_1239.jpg   Dry Sumping Volvo DPR'S-img_1223.jpg
Dry Sumping Volvo DPR'S-img_1224.jpg   Dry Sumping Volvo DPR'S-img_1228.jpg   Dry Sumping Volvo DPR'S-img_1227.jpg
Dry Sumping Volvo DPR'S-img_1229.jpg   Dry Sumping Volvo DPR'S-img_1232.jpg   Dry Sumping Volvo DPR'S-img_1222.jpg
peterunwin is offline
Old 05-18-2014 | 07:37 AM
  #142
A few more pictures
Attached Thumbnails Dry Sumping Volvo DPR'S-img_1217.jpg   Dry Sumping Volvo DPR'S-img_1218.jpg   Dry Sumping Volvo DPR'S-img_1220.jpg
Dry Sumping Volvo DPR'S-img_1221.jpg   Dry Sumping Volvo DPR'S-img_1215.jpg   Dry Sumping Volvo DPR'S-img_1216.jpg
Old 06-13-2014 | 03:53 PM
  #143
Hi All,
Got the drives installed today, tomorrow i will start the pipe work for the dry sump system.
Peter
Attached Thumbnails Dry Sumping Volvo DPR'S-img_4931.jpg   Dry Sumping Volvo DPR'S-img_4933.jpg   Dry Sumping Volvo DPR'S-img_4934.jpg
Dry Sumping Volvo DPR'S-img_4935.jpg   Dry Sumping Volvo DPR'S-img_4936.jpg   Dry Sumping Volvo DPR'S-img_4937.jpg
Dry Sumping Volvo DPR'S-img_4938.jpg   Dry Sumping Volvo DPR'S-img_4939.jpg   Dry Sumping Volvo DPR'S-img_4941.jpg
Old 06-16-2014 | 12:08 PM
  #144
Hi All,
Fitted carbon fibre air intake for additional ventilation, also filled the drives with oil installed the props and mocked up the transducer brackets.
Peter
Attached Thumbnails Dry Sumping Volvo DPR'S-img_1242.jpg   Dry Sumping Volvo DPR'S-img_1243.jpg   Dry Sumping Volvo DPR'S-img_1249.jpg
Dry Sumping Volvo DPR'S-img_1250.jpg   Dry Sumping Volvo DPR'S-img_1251.jpg   Dry Sumping Volvo DPR'S-img_1252.jpg
Dry Sumping Volvo DPR'S-img_1253.jpg   Dry Sumping Volvo DPR'S-img_1254.jpg   Dry Sumping Volvo DPR'S-img_1255.jpg
Old 06-18-2014 | 08:13 AM
  #145
Peter,
Didn't look for a while, hat off!! Got a lump in my throat watching these drives
best regards
Paul
denpol is offline
Old 06-20-2014 | 12:13 PM
  #146
Thanks Paul,
Today i made all the dry sump hoses between the drives and transom and also did the final fit on the steering transducers these are submersible to 2 meters but should only get splash most of the time.
Peter
Attached Thumbnails Dry Sumping Volvo DPR'S-img_1257.jpg   Dry Sumping Volvo DPR'S-img_1258.jpg   Dry Sumping Volvo DPR'S-img_1259.jpg
Dry Sumping Volvo DPR'S-img_1260.jpg   Dry Sumping Volvo DPR'S-img_1261.jpg   Dry Sumping Volvo DPR'S-img_1262.jpg
Dry Sumping Volvo DPR'S-img_1263.jpg   Dry Sumping Volvo DPR'S-img_1264.jpg   Dry Sumping Volvo DPR'S-img_1266.jpg
Old 06-20-2014 | 02:57 PM
  #147
Default The end is in sight
Originally Posted by peterunwin
Thanks Paul,
Peter
High Tech! Great.
Will you throw the champagne bottle this summer?
cheers
Paul
denpol is offline
Old 06-20-2014 | 03:07 PM
  #148
1 MAIDEN AMERICA's Avatar
Any concern with the weight of the lines for the dry sump hanging off the fittings? Generally, boats seem to have the internal lines, wires, hoses, etc secured every 6-8 inches, and external lines are are fairly short. Frickin' awesome project though. What's the calendar look like for June?
1 MAIDEN AMERICA is offline
Old 06-21-2014 | 11:43 AM
  #149
Originally Posted by denpol
High Tech! Great.
cheers
Paul
Thanks Paul,
We are about 3 weeks away until her first splash subject to weather
Peter
Old 06-21-2014 | 12:02 PM
  #150
Thanks MAIDEN AMERICA,
My day job is designing and building small hydraulic drill rigs and i very often use unsupported hose on these and finds it works really well.On the boat i have used 3 hoses which are cable tied together and they have to accommodate all the steering movement and trim, they are way over specked for their purpose and as such they are mechanically very very strong, they have a working pressure of 5000 psi with a three times safety factor two are being used with a small vacum the other four are a little over atmospheric.
Peter
