Dry Sumping Volvo DPR'S >
Old 06-29-2014 | 04:35 AM
  #151
Hi All,
Spent Thursday and Friday trimming the carbon screen also had to cut a 2ft long rebate in the deck as the screen is much longer than the standard one, then yesterday i enlisted the help of my first mate….. to assist with positioning the screen on a generous bead of tiger-seal, a pretty messy job then a massive clean up….
Peter
Attached Thumbnails Dry Sumping Volvo DPR'S-img_1285.jpg   Dry Sumping Volvo DPR'S-img_1286.jpg   Dry Sumping Volvo DPR'S-img_1287.jpg
peterunwin is offline
Old 06-29-2014 | 09:12 AM
  #152
am I supposed to focus on the wind screen or the ,,forgot what the shirt says.looks good both of them.
sutphen 30 is offline
Old 07-19-2014 | 01:45 PM
  #153
Hi All,
Cheetah purrs into life both motors started on the button:
Peter
https://www.youtube.com/watch?v=MNldI5GadCk
Old 07-25-2014 | 03:13 PM
  #154
Hi All,
Cheetah gets her carbon front trim wing permanently installed:huge grin:
Peter
Attached Thumbnails Dry Sumping Volvo DPR'S-img_1388.jpg   Dry Sumping Volvo DPR'S-img_1387.jpg   Dry Sumping Volvo DPR'S-img_1396.jpg
Dry Sumping Volvo DPR'S-img_1395.jpg   Dry Sumping Volvo DPR'S-img_1394.jpg   Dry Sumping Volvo DPR'S-img_1393.jpg
Dry Sumping Volvo DPR'S-img_1392.jpg   Dry Sumping Volvo DPR'S-img_1390.jpg   Dry Sumping Volvo DPR'S-img_1389.jpg
Old 07-25-2014 | 03:28 PM
  #155
Peter your work is flawless as always but I have to say that wing really looks out of place up there. I hope it makes a huge difference in the performance of the boat!
pstorti is offline
Old 07-27-2014 | 11:29 AM
  #156
Peter
Looks high tech.respect!
Am not familiar with wings at the bow, is it active, since I notice wires going to it?
keep it coming
Paul
denpol is offline
Old 08-10-2014 | 05:21 AM
  #157
Originally Posted by denpol
Peter
keep it coming
Paul
Hi Paul,
At the moment the wing is moved by linear actuators, the calculated lift at 75mph is 250lbs and the aim is to be able to trim the boat with the wing so the drives can remain parallel to the water, if it works successfully i will remove the linear actuators and install high speed hydraulic cylinders powered of engine driven pumps to make the wing fully active.
Peter
Old 08-10-2014 | 05:23 AM
  #158
Cheetah gets her new graphics..
Peter
Attached Thumbnails Dry Sumping Volvo DPR'S-img_1418.jpg   Dry Sumping Volvo DPR'S-img_1427.jpg
Old 08-10-2014 | 08:23 AM
  #159
Peter
Is your carbon exhaust tubing treated with special heat resistant resin or is the regular vinylester tube good enough? (Since I sea not much water coming out of the exhaust )
Cheers
Paul
denpol is offline
Old 08-10-2014 | 08:48 AM
  #160
Hello Peter,
Thanks, you're definately not afraid to explore new paths.
If it is succesfull you could patent it as the " UNWING"
Are you familiar with Navatek's aft lifting body system? Despite 100% the opposite, it could give you ideas.
http://www.navatekltd.com/aftlbsover.html
Aye aye
Paul
denpol is offline
