Dry Sumping Volvo DPR'S
#32
During the rebuild process i have been able to save a substantial amount of weight in the engine compartment, moving the engines closer together has allowed me to reduce the engines centre of gravity by 1.5" and at the same time decrease the X dimension by 1". I have also moved the engines forward by 5.2" as the engine and drive package weighs approximately 750 kg each this will move the longitudinal centre of gravity further forward as the boat previously was always a bit stern heavy.
Peter
#33
Hi PhatboyC,
I think the guys at chipexpress may be living in a fantasy world because the standard 350/370 charge cooler and heat exchanger will not support powers any greater than 400hp even in England where our average water temperature does not exceed 12 degrees centigrade, we have found it necessary to modify the cooling system. Even with the mods exhaust gas temperature is on the high side. We also deliberately map out the torque to make the drives live.
Regards
Peter
Regards
Peter
Hi fatboyc
I tried those boxes on my 320hp cummins and they do absolute nothing not even in the higest setting we had added boost gauges to see what happend but it was nothing not even smoke increase . The told me that I would see a 50 hp gain for each motor , I tried it because they offered full funds return when not happy and the did .
Bor
#34
Hi All,
I have finished the rebuild of the transom shields these have now been painted and the carbon cover plates fitted ready for installion to the boat, i have also decided to make some carbon fibre power steering oil coolers as the standard volvo units obstruct the water inlet flow and cause weed hangups. The electro-hydraulic pumps have also arrived for the dry sump system.
Peter
Peter
#36
Hi fatboyc
Bor
Bor
#38
Peter
#39
peter,
i'm ready to start upgrading my d6 350's . cant find anyone in the states that sells a plug in chip box or remaps ecu's. did you remap your own or can you recommend some one you trust ? i'd like a plug in box but haven't found anyone who has run a chip express ( or others ) that has had them work on the volvo d6's. looking for about the 400 hp mark with as little torque increase as possible.
then want to have the props worked on to get more top end out of them. i sure would appreciate any help .
p.s. let me know if your going to fantasy fest. we might take the boat down from naples, its only 3 hours.
#40
peter,
We are still contemplating coming out to fantasy fest and the world powerboat championships, we are also thinking of buying a boat to keep in Florida while we look for a house we just can't decide where we want to live there are just so many nice places...
All The Best
Peter
