Dry Sumping Volvo DPR'S >
Old 09-18-2012 | 01:01 PM
  #51
Hi All,
Had a busy few weeks, transom shields are installed permanently and today engines were trial fitted so that i can do most of the rigging and exhaust fabrication, i will then pull them back out finish the paintwork in the bilges then install them for good. Although they are quite close together there is ample working room. I bought the extended bell housings from volvo as they were both cheaper and lighter than making my own from billet. The PCU'S are now mounted on the engines next to the ECU'S so she is getting a completely new wiring system.We are hoping to wake up the trim functions that we believe are dormant on the 435 engine will let you know how this goes.
Peter
Attached Thumbnails Dry Sumping Volvo DPR'S-img_0221.jpg   Dry Sumping Volvo DPR'S-img_0222.jpg   Dry Sumping Volvo DPR'S-img_0223.jpg
Dry Sumping Volvo DPR'S-img_0224.jpg   Dry Sumping Volvo DPR'S-img_0225.jpg   Dry Sumping Volvo DPR'S-img_0226.jpg
peterunwin is offline
Old 09-18-2012 | 01:06 PM
  #52
A few more pictures
Attached Thumbnails Dry Sumping Volvo DPR'S-img_0228.jpg   Dry Sumping Volvo DPR'S-img_0229.jpg   Dry Sumping Volvo DPR'S-img_0230.jpg
Dry Sumping Volvo DPR'S-img_0231.jpg   Dry Sumping Volvo DPR'S-img_0232.jpg   Dry Sumping Volvo DPR'S-img_0233.jpg
Old 09-18-2012 | 02:46 PM
  #53
WOW! What an amazing project! Very cool. Thanks for sharing your build and all the great pics.
offshorexcursion is offline
Old 09-20-2012 | 06:03 PM
  #54
Some more pictures of Peter's project
Attached Thumbnails Dry Sumping Volvo DPR'S-161.jpg   Dry Sumping Volvo DPR'S-162.jpg   Dry Sumping Volvo DPR'S-163.jpg
Dry Sumping Volvo DPR'S-164.jpg   Dry Sumping Volvo DPR'S-165.jpg   Dry Sumping Volvo DPR'S-166.jpg
Dry Sumping Volvo DPR'S-167.jpg   Dry Sumping Volvo DPR'S-168.jpg   Dry Sumping Volvo DPR'S-169.jpg
Old 09-20-2012 | 06:05 PM
  #55
And a few more
Attached Thumbnails Dry Sumping Volvo DPR'S-171.jpg   Dry Sumping Volvo DPR'S-172.jpg   Dry Sumping Volvo DPR'S-174.jpg
Dry Sumping Volvo DPR'S-175.jpg   Dry Sumping Volvo DPR'S-176.jpg   Dry Sumping Volvo DPR'S-177.jpg
Dry Sumping Volvo DPR'S-179.jpg   Dry Sumping Volvo DPR'S-180.jpg   Dry Sumping Volvo DPR'S-181.jpg
Old 09-20-2012 | 06:11 PM
  #56
And a few more
Attached Thumbnails Dry Sumping Volvo DPR'S-183.jpg   Dry Sumping Volvo DPR'S-184.jpg   Dry Sumping Volvo DPR'S-185.jpg
Dry Sumping Volvo DPR'S-186.jpg   Dry Sumping Volvo DPR'S-187.jpg   Dry Sumping Volvo DPR'S-188.jpg
Dry Sumping Volvo DPR'S-189.jpg   Dry Sumping Volvo DPR'S-190.jpg   Dry Sumping Volvo DPR'S-191.jpg
Old 09-20-2012 | 06:12 PM
  #57
And the last few for today
Attached Thumbnails Dry Sumping Volvo DPR'S-193.jpg   Dry Sumping Volvo DPR'S-195.jpg   Dry Sumping Volvo DPR'S-196.jpg
Old 09-20-2012 | 10:36 PM
  #58
C_Spray's Avatar
Diamond Member #001
You have to love the simplicity of the rear engine mount/transom assembly design that VP uses. I noticed that you put the bellhousings in first, and then bolted the engines to the bellhousing instead of dropping the entire assembly in at once. Any particular reason for that?
Very clean setup, by the way...
C_Spray is offline
Old 09-22-2012 | 11:37 AM
  #59
Hi Chuck,
Although it is not obvious in the photographs the engines and bell housings are much longer than the engine bay opening, so by fitting the bell housings first i can drop the engines in horizontally and as the bell housings are much longer all the bolts are very easy to get at. It also means you can get the engines in and out without removing the drives. I have now started the hydraulic and electrical rigging also mounted the fuel filters to establish hose lengths.
Peter
Attached Thumbnails Dry Sumping Volvo DPR'S-img_0238.jpg   Dry Sumping Volvo DPR'S-img_0239.jpg   Dry Sumping Volvo DPR'S-img_0240.jpg
Dry Sumping Volvo DPR'S-img_0241.jpg   Dry Sumping Volvo DPR'S-img_0242.jpg   Dry Sumping Volvo DPR'S-img_0243.jpg
Dry Sumping Volvo DPR'S-img_0244.jpg   Dry Sumping Volvo DPR'S-img_0246.jpg   Dry Sumping Volvo DPR'S-img_0248.jpg
Old 09-24-2012 | 10:51 PM
  #60
C_Spray's Avatar
Diamond Member #001
Nice. Wish that I owned a hydraulics shop like you...
C_Spray is offline
