New clutch
Old 02-20-2012 | 06:41 PM
Default New clutch
my spare xr drive has a worn clutch,,, what is the best way to repair it,,install new forward and reverse gears,,,or can i just install a new clutch,,,iam thinking new gears also,,,whats do you guys say???
TWIN-SPINS is offline
Old 02-21-2012 | 03:15 PM
Mr Gadgets's Avatar
Charter Member #601
Depends on what the surface the cone rides on, looks like. I have cleaned them up with a dremel flap wheel while spining them in the lathe. The cone usually gets the most wear, unless it was locked up??
Mr Gadgets is offline
Old 02-21-2012 | 05:41 PM
their you go,best source of information you can get on drives anyplace.
mike tkach is offline
Old 02-22-2012 | 07:30 AM
So how much material do you take off doing it that way. Knowing the specs of that cup I would not think that would be a good practice to pass along to the boating community.
waconda is offline
Old 02-22-2012 | 01:32 PM
Mr Gadgets's Avatar
Charter Member #601
I just polish the surface. I am guessing, maybe, .0002". Never tried to measure it.
Note: Don't try this at home. It may not be an approved process.
Old 02-22-2012 | 05:17 PM
LOL I like the last line.
waconda is offline
Old 02-22-2012 | 05:43 PM
standard disclaimer at the end of every post: "this information is for entertainment purposes only. if it blows up in your face, you either did it wrong, or you were stupid to listen to us in the first place."
dereknkathy is offline
Old 02-22-2012 | 09:07 PM
pqjack is offline
Old 02-23-2012 | 03:08 AM
Hi TWIN-SPINS.
When mating new components with old i always hand lap with fine lapping paste seems to work very well.
Regards
Peter
peterunwin is offline
Old 02-23-2012 | 06:51 AM
Originally Posted by peterunwin
Hi TWIN-SPINS.
Regards
Peter
Is that KY lapping paste or crest? I just what the correct stuff.
waconda is offline
