Why Not Run Bravo as Surface Drive? >
Old 03-22-2012 | 05:24 PM
  #31
bor's Avatar
bor
Originally Posted by Airpacker
bor, does that hull have natural bow lift? You wil find the BH drive does nothing but shoot a higher rooster tale when you trim up. It takes forward speed and a natural bow lifting hull to make that drive work properly.
Not very much but hoping that the power and big props will lift it and the hull is very light bare hull weights 800lbs otherwise I have a new bravo 1 X for it but then I probably need a -3" shorty .
bor is offline
Old 03-22-2012 | 05:27 PM
  #32
bor's Avatar
bor
Originally Posted by Pokher Ace
Bor
Have you ran that exhaust yet? From the pics it looks like it runs uphill??
Not yet ,the turns are going up yeah ,but there is a drain in the lowest point so I can drain all water out and the pipes are dry to the end due to reversion ,I will dump cool water above the gimbal
bor is offline
Old 03-23-2012 | 12:22 AM
  #33
Why did Mercury discontinue the Black Hawk drives? It actually seemed like a good idea, with half the load to the prop blades, and counter-rotation, so no stern crawl.
Michael
Michael1 is offline
Old 03-23-2012 | 12:33 AM
  #34
bor's Avatar
bor
Michael
What I heard was that the production costs where to high and the hull must be adjusted to the carastics of the drive .
bor is offline
Old 03-23-2012 | 12:57 AM
  #35
Was a really good idea, just didn't handle much power. Props were a bit difficult to come by as well from what I've heard. I have a friend that has one sitting in storage, I can't tell you how many times I've thought about trying it out just to see how it handles on my boat... Just seemed a waste to destroy a perfectly good drive!
lvrepoman is offline
Old 03-23-2012 | 11:00 AM
  #36
Airpacker's Avatar
cost period. cost more to make, buy and prop. Didn't work well on many hulls they tried it on because they need natural bow lift. Somewhat tricky around docks in single applications too.
Airpacker is offline
Old 03-25-2012 | 07:48 AM
  #37
Official OSO boat whore
Actually, I believe those props were on a Donzi Blackhawk 22, that or maybe a Cig 20. Unfortunately, neither was my boat. I have a bunch of photos, all labeled "bniedospial".
Attached Thumbnails Why Not Run Bravo as Surface Drive?-bniedospial208.jpg   Why Not Run Bravo as Surface Drive?-bniedospial209.jpg   Why Not Run Bravo as Surface Drive?-bniedospial210.jpg
Cord is offline
Old 03-25-2012 | 07:57 AM
  #38
These were my props. They were custom made by Hoss. I think the line of props were called "Hyper Drive". The idea was to use a chopper style prop so there was a bit more bow lift. Notice the solid hub.
Attached Thumbnails Why Not Run Bravo as Surface Drive?-bh-hoss-hyperdrive-prop.jpg   Why Not Run Bravo as Surface Drive?-bh-hoss-hyperdrive-props.jpg   Why Not Run Bravo as Surface Drive?-img_8882.jpg
Why Not Run Bravo as Surface Drive?-img_8883.jpg   Why Not Run Bravo as Surface Drive?-img_8884.jpg
Cord is offline
Old 03-25-2012 | 08:05 AM
  #39
Now for a little prop porn. Having been out of boats for a number of years, I sold everything last year so I could buy a atv for my wife. The atv has been a ton of fun, more fun than the props brought me sitting on the shelf.
Anyways, you are looking at Merc 27, 29 and 31" props. The Hoss props are on the right. The buyer also took the drive. I later found another set of 31's that I didn't take a picture of.
Cord is offline
Old 03-25-2012 | 08:10 AM
  #40
This is a set up sheet that Merc put out when the drive was introduced. Thought it might be helpful to somebody setting up their boat.
File Type: pdf
Cord is offline
