alpha gear ratio
Old 04-21-2012 | 07:25 PM
Default alpha gear ratio
got a friend that says he has a 1.32 to1 ratio in an alpha gen 2 could this be true or is the 1.48 the lowest gears available?
mach1magnum is offline
Old 04-21-2012 | 11:02 PM
Default fixx
he could be rite,,they usually use that ratio if it has a big block in front of it,,common in the later 80's and early 90's.
FIXX is offline
Old 04-22-2012 | 06:06 AM
Mbam's Avatar
Offshoreonly Advertiser
Fix is right, was standard on the 454 Magnum Alpha package,
Mbam is offline
Old 04-22-2012 | 06:08 AM
nice thanks you guys always gots the answers
Old 04-22-2012 | 06:23 AM
Biggus's Avatar
There were no Gen II 454 Alpha packages. Gear ratio's for the Gen II Alpha are 2.40, 1.98, 1.84. 1.65 and 1.50 -No 1.32 offered for the Gen II
Biggus is offline
Old 04-22-2012 | 06:28 AM
Mbam's Avatar
Oops - Biggus is right, I missed the Gen 2 part. Too early in the AM
Mbam is offline
Old 04-22-2012 | 06:45 AM
then is the only way to tell if its and alpha 2 is if it has the oil bottle inside or is it possible to put an alpha 2 on and alpha 1 gimble?
