imco sc question
Old 10-02-2012 | 08:01 PM
Default imco sc question
putting new imco gimble rings and bells on my boat and when i removed drives{ imco sc s} i noticed the u joints bad .i called imco and they say they are $228.00 each also the same as xr drives i told them i had 2 diff cap sizes 1.328 and 1 .217 . they claim they are all the same size .so is the guy i talked to wrong ??.he also said i could buy them from mercruiser for an xr if so whats the part # im looking for. i know the early xrs had real big joints and those are no longer avail .looking to get this back together for a run in conn. thanks
smokin' gun is offline
Old 10-02-2012 | 08:16 PM
I have two different sizes also.
Steve
smiklos@sunprint is offline
Old 10-02-2012 | 08:36 PM
Mr Gadgets's Avatar
Charter Member #601
The 1.328, should have grease fittings and are the old XR ujoints, Merc PN 862132T. Bam shows them still available for $170.31
The 1.217, should not have grease fittings and are the new XR ujoints, Merc PN 866136A01. Bam shows them for $203.17.
This is what I found when researching the it.. If you go to Bam's site and look at the drawing look up.. those are the pn's they show.
Hope that helps.
Dick
Mr Gadgets is offline
Old 10-03-2012 | 04:49 AM
Hope that helps.
Dick
im looking for the part # of the joint with 2 diff size caps one side is 1.328 the other side is 1.217 thanks
Old 10-03-2012 | 05:52 AM
Mr Gadgets's Avatar
Charter Member #601
That is a new one on me. I have not seen that joint before.
Dick
Old 10-03-2012 | 06:06 AM
Conversion joint, never seen them on a drive but in pieced together trucks plenty of times
Unlimited jd is offline
Old 10-03-2012 | 07:05 AM
Here is a link for the 1.328 ujoint http://www.bravoshop.net/index.php?m...2132&x=10&y=10
waconda is offline
Old 02-14-2015 | 02:22 PM
mtm's Avatar
mtm
Anyone figure this out
mtm is offline
