X Dimension on 24x7 >
X Dimension on 24x7
X Dimension on 24x7
Old 12-10-2012 | 05:59 AM
Hang a line down centerline of transom or standoff box to determine actual height before cutting.
Steve
smiklos@sunprint is offline
Old 12-10-2012 | 02:54 PM
Originally Posted by lil red
yes it is, but when measuring to cut the x, you need to measure straight up the transom perpendicular to the bottom to get the actual x dimesnsion. taking the angle of the transom out of the equation, measuring parallel with the transom would give you a longer measurement but the hole still in the same place. Just making sure were all talking the same measurement. I'll have to check how far below the pad the propshaft is.
Prop shaft is about -3"
scarab63 is offline
Old 12-10-2012 | 03:08 PM
tomas_wallin's Avatar
If you're at 3" with the prop shaft parallell to the bottom (not the pad) you're at an X a bit higher than 17".
tomas_wallin is offline
Old 12-10-2012 | 04:29 PM
Yep my memory must be shot! Sorry guys
Unlimited jd is offline
Old 12-10-2012 | 05:51 PM
If I remember I was waffling between 17 & 18 so we split the difference....
Also my -3" is by eye......no straight lines or anything so easily +/-
scarab63 is offline
Old 12-10-2012 | 05:53 PM
It happens!
scarab63 is offline
Old 12-16-2012 | 07:55 PM
THANKS for all the replies. !
Finally cut it today..
.... Went with 18.5"
Boatally Insane is offline
Old 12-17-2012 | 04:02 AM
Will you do the bottom as well?
Old 12-17-2012 | 07:08 AM
I already had it flipped and shapened the edges of the strakes and the pad.
No hook in the hull at all...
http://www.offshoreonly.com/forums/e...r-project.html
Old 09-14-2014 | 09:53 AM
Did this ever hit the water? Results?
26 Spyder is offline
