another b1 vs. xr question >
Old 02-12-2013 | 04:07 PM
Default another b1 vs. xr question
I know this has been gone over a zillion times but just to recap.
I broke a b1 at the end of the season last year, it broke the upper gears. Boat is a 96 31' scarab with procharged 502's. I was thinking about switching over to xr's but it seems like they break just as much as the b1's. So on to my question, are they really that much stronger to quantify the expense over the b1's? Im leaning towards keeping the b1's on the boat and just building some spares. If im going to break them at close to the same rate I would rather be building and buying b1's over the xr's. Am i close on my thinking?
indysupra is offline
Old 02-12-2013 | 04:25 PM
The XR's are stronger....theoretically....but the quality/finish of the gears leaves a lot to be desired...there is a member here working on an improved set...if you want an XR,try to find an older one...apparently the gears are of better quality...
not a drive expert,but i do run an xr...so far,no problems
pqjack is offline
Old 02-12-2013 | 04:30 PM
Yes, I can tell you from personal experience that the XR is quite a bit stronger.
thirdchildhood is offline
Old 02-12-2013 | 05:05 PM
Can XR gears be put in a XZ drive
Drock78 is offline
Old 02-12-2013 | 05:15 PM
bwd
Yep.
bwd is offline
Old 02-12-2013 | 06:09 PM
Doing so would basically make it an XR
JaayTeee is offline
Old 02-12-2013 | 06:44 PM
Is it just the gears or are shafts and bearings different
Drock78 is offline
Old 02-12-2013 | 09:24 PM
Go see George at All American Drive. He built mine when I upped my power to 525 efi's in my PowerPlay. He as a 2 year warranty
AB69Z is offline
Old 02-13-2013 | 06:37 AM
bwd
Check out Bam's website. they have a bravo chart that shows the differences.
bwd is offline
