Bravo one removal
Old 09-03-2013 | 04:13 PM
Default Bravo one removal
helping a friend remove his outdrive (bravo 1) neither of us have done it before but everybody says it is fairly easy. do we put it in drive or neutral before we remove it is my only question at this point.
another thing almost forgot the drive cables are disconnected from the motor so I have no idea what postion the cable is in at this point. I was going to go and look at my boat and compare my cable to his as a comparison. hopefully I can figure it out by mine
Any other pointers would be helpful would be great also.
TOMMY22555 is offline
Old 09-03-2013 | 04:33 PM
Doesnt matter on the shifter position,
You may have the speedo hose that plugs in right below the exhaust inlet of the helmet that
you'll need to disconnect if it's still intact..... it's yellow in color and you rotate it 90* and it should pull right out.
The rest is the 6 nuts holding the drive on, and the trim cyl pin and off it will come.....when it comes out
a little way, just check to make shure the latch jaw on the shift lever ( in the drive) opens and releases the shift cable.
JaayTeee is offline
Old 09-03-2013 | 05:47 PM
Thank you for the info rather ask a question then break something
Old 09-04-2013 | 12:18 AM
Lots of videos on YouTube on this. Google it, and you can see it being done first hand. It is easy once you have done it. Having a lift or another person is helpful as well but it can be done by yourself.
blefever is offline
Old 09-04-2013 | 07:48 AM
I did the, watch 6 thousand youtube videos, when I removed mine and it was still a pain in the ass!!! Dam near was using a slide hammer to pull it backwards!!! Then to get it back on, that was another PITA!.
Seemed like to me that the 2 o-rings on the input shaft was/is the issue and getting the one threw the gimbal bearing!! a pound of grease and and can of WD40 later I was able to squeeze it on using the 6 studs and nuts. 1/4 turn a piece one at a time.
92nsx is offline
Old 09-04-2013 | 09:03 AM
Sometimes they are hard to remove but if the gimble/couple are aligned it should go back on fairly easy. If your using the studs and nuts to pull it all the way on there is usually an alignment issue.
indysupra is offline
Old 09-04-2013 | 12:02 PM
+1 I would certainly check alignment if you are having that much trouble getting it back together. I have fought with them coming off, but I would NEVER use the nuts to pull the drive on.
RT930turbo is offline
Old 09-10-2013 | 07:38 AM
<---- buying an alignment tool before I remove the drive next time.
92nsx is offline
