Help identify merc alpha ss lower unit >
Old 09-23-2013 | 09:23 PM
Default Help identify merc alpha ss lower unit
I have a alpha ss drive that I have been told runs a outboard CLE lower unit. I have broke my lower unit, don't think its good.when there is witness marks of something trying to come out lol. I have a few numbers that might tell us what it is.. they were hard to read so they might be wrong
1L85E125
1647 9559-c
Is there a guru to talk to about HD parts? If they make any. I am running this drive behind a 600 +hp 18.5' powerplay around 3000 lbs.
Any advice is appreciated
mountainmadness is offline
Old 09-23-2013 | 10:47 PM
No real HD parts. Good luck finding a vertical shaft. A CLE outboard lower will work if you shorten the vertical shaft and you need to add a oil transfer port so oil will fill the upper. If you lost the upper, plan on finding a new drive.
ACrooks69 is offline
Old 09-30-2013 | 05:02 PM
I have a complete Alpha SS in my basement if you are interested. Was the spare drive on a boat I sold a couple years ago.
papps is offline
Old 09-30-2013 | 07:00 PM
If mountainmadness isn't interested in your drive I maybe.
Thanks justin
inlinepwr is offline
Old 10-04-2013 | 08:00 PM
Thanks for the offer, I am working on a few places to make up sum parts if I can't find them
Old 10-04-2013 | 09:08 PM
Bravo time Travis!! You won't have to worry about breaking it with that light boat. I've wondered when my SS will let go so I try and be somewhat easy on it.
Ryan00TJ is offline
Old 10-14-2013 | 08:39 PM
This is a good thread on the alpha SS.
http://www.offshoreonly.com/forums/g...-ss-worth.html
papps is offline
Old 10-22-2013 | 02:47 PM
I just sold my alpha ss for $1800.
600 hp into an alpha is a breakdown waiting to happen. You are running double the power rating for the ss. Might be time to do what I did....replace the alpha with a bravo, then ride like you stole it.
gellis11 is offline
