trim switch replacement, tools and whats else
Hello all,
I am doing some research possibly getting ready to pull my Bravo III drive. The problem I am experiencing is the trim button "UP" is not working on the throttle. It does work with the trailer button and goes down with the throttle button. Info on the web states its the trim switch / limit on the drive. Is there a way to actually test this switch before pulling the drive maybe checking resistance?
So my questions is this, if I have to pull the drive I am planning on a complete maintenance:
Gimbal bearing
Gimal Bellows
Throttle Bellow
Trim limit
Trim Switch
Intake water hose
Am I missing anything else?
Also, I see there are some special tools that are needed to accomplish this. Are this tools really needed are are there substitutes:
Hinge Pin Tool - 91-78310
Sleeve Removal Tool - 91-818169
Sleeve Installation Tool - 91-818162
Driver Rod - 91-37323
Driver Head - 91-36569
Bellow Expansion Tool 91-45497A1
Tapered Insert Tool 91-43579
Is this how most do it or is it a simple enough job to just go in for the switches and only fix whats needed.
Gimbal bearing
Gimal Bellows
Throttle Bellow
Trim limit
Trim Switch
Intake water hose
You need the hinge pin removal tool. everything else you can get by with a little improvisation. If your replacing the pucks, you need take the gimble apart anyways. its not that technical or anything, just a time consuming occasionally frustrating job.
Ayuh,.... A 1/2" allen drive fits the 12 point pin, No problem,...
Cool thanks Bondo and phragle
What other tools have you used to replace the other special tools? I have never done this before and don't want to get stuck by not having the tools to complete the job
