TRS transom assembly hole size >
Old 09-13-2014 | 03:54 PM
Default TRS transom assembly hole size
The studs on the transom assy are 1/2 what is the acceptable oversize for drilling the holes in the transom?
sparky24 is offline
Old 09-14-2014 | 08:34 PM
Ayuh,.... Drill 1/2" holes, 'n adjust as necessary,...
Bondo is offline
Old 09-15-2014 | 05:55 AM
5/8, bravos use 7/16 studs and the drill size is 9/16
Unlimited jd is offline
Old 09-15-2014 | 09:37 AM
thank you thats what i thought, i drilled to 9/16 and it fits but could use some wiggle room
sparky24 is offline
