Drive discussion: trs.  3's. And 5's >
Old 01-04-2015 | 12:46 AM
  #61
Originally Posted by 14 apache
Original poster RMPRam
Lil red is correct. All the #4's have a "polygon shape" front driveshaft, while some of the early #5's did also. In my opinion, the polygon shaft is just as "good" as the splined version that Mercury switched to in the later #5's. None, again from my sources, of the #4's had the near net forged, straight cut upper gear sets. They were a later "up-grade" in the #5's. The lower gear sets, RH and LH internal splines, on the #4's and the #5's are different with the #4's having fewer splines on the pinion gears, than the later #5's. A #4 can be upgraded to be, again in my opinion, as strong as a #5 with the addition of a set of the net forged, straight cut polygon'd upper gears and also the 1.75" dia. propshaft. I have both of these pieces, new, available for the #4. Check my classified ad for more information. If I can be of any help, please don't hesitate to give me a call.
Gary
612-247-7081
I have a set of Big Shaft, straight cut gears #4`s so in reality it`s really a #5
See this should help Dave understand the differences.
ICDEDPPL is offline
Old 01-04-2015 | 07:21 AM
  #62
Merc developed the SSM III drive for racing. It was a stronger drive than the TRS for that. After a while, the surface drive (arneson boats) showed up. Merc's rebuttle was the #4 drive. The #4 drive, was much shorter than a #3. It did not have a cavitation plate (prop clearance), and had a much larger skeg for surfacing stability. After a while, an upgraded version was needed, as the racing engines were getting more powerful, boats going faster, etc. Merc then upgraded the #3, to the #3A. The #4, to the #5. Most upgrades were done internally. Straight cut gears, thicker spur gears, larger propshafts etc. The #3, and #4, had 19 spline shafts. While substantially larger and stronger than a TRS, bravo, or XR propshaft, they still went bigger, to the 1.750 shaft like the #6, 26 spline style. Plenty of used 3 and 4 blade props out there for relatively easy money. Last couple sets of SSM 4 blade props, I've paid less than 2g per pair.
As far as the #5 being stronger than the 3A, I dont believe that is true. They both share the same style internals, just the 5 is the shorty version. These drives share nothing in common with a TRS, SSM 2, or Konrad. Design wise, they are more similar to a #6 than they are a TRS.
The #5 lower case, is also beefed up over the #4 lower case. Hard to tell by looking, but its a bit beefed up in thickness. I think this was due to some of the old race cats, cracking the lowers on #4's at high speeds in big water. Probably an issue most pleasure boats wont see.
The #4, and #5 series of drives, allow you to keep engine mounting height, reasonable. For example, if you were to install #3/3a drives on a 33 fountain, or 33 powerplay, youd have to mount the engines very high, to get the best propshaft height. Clearance would be an issue. Cutting into the rubrail, extreme blower hatches, etc. The #4, and #5, are about 5.5" shorter than a #3/3A, but can be spaced up to 3'' down. This is a very nice feature, esp if your running tall roots style blowers. Right off the bat you're getting almost 6'' of hatch clearance.
As stated, many many #4 drives, are called #5's, when in reality they are 4's that have big shafts. My 4's have 240 hours on them since they were installed on my boat. Prior to that, I am not sure if they were gone thru at that point, or not. But, for 240 hours, they have had blower motors in front of them. Knock on wood, I havent had a lick of trouble with them, other than a propshaft seal leak. I wouldnt say I am easy on them, lots of 3000RPM to full throttle accelerating, rough water, etc.
After owning a couple TRS boats, a couple bravo boats, I've decided the 3,4,5 drives are for me. Not only do they simply hold up well to a beating, I love the way the SSM boats handle big water. #6 boats are out of my budget, but plenty of SSM 3,4,5 boats I can afford.
I've seen guys claim 700HP will live with a TRS, bravo, etc. While that may be true, you're not gonna be getting any life out of it, unless you go easy. Bolt a #5 on it with 700's, and go drive it like an offshore cowboy, and it will still outlast that TRS.
File Type: pdf
File Type: pdf
File Type: pdf
MILD THUNDER is offline
Old 01-04-2015 | 07:32 AM
  #63
Originally Posted by phughes69
As far as the rest here is my ranking.
1 M8
2 SSM 6 dry sump
3 SSM 6 wet sump
4 Arneson
5 Kamma
6 SSM 4/5
7 SSM 3A
8 Bravo XR sport master
9 SSM 3
10 TRS/ SSM II
10 Bravo 1
11 Alpha
There is absolutely no way in hell, that a SSM III, should be rated below and XR sportmaster!. Or a KAAMA better than a 3A, 4, 5....I'll give my ranking list lol
#1 Arneson
#2 M8
#3 SSM 6 dry sump
#4 SSM 6 wet sump
#5 SSM 3A/5
#6 SSM 4
#7 SSM 3
#8 Konrad
#9 Kaama
#10 Bravo XR Sportmaster
#11 TRS/SSM II
#12 Standard Bravo
#13 Alpha
Just my opinion!
Old 01-04-2015 | 08:26 AM
  #64
Where does a Volvo drive or OMC come into play???
88bullet is offline
Old 01-04-2015 | 08:53 AM
  #65
Stronger than any of the bravo crap
indysupra is offline
Old 01-04-2015 | 09:10 AM
  #66
Ice and mild what transmissions are you guys running?
Old 01-04-2015 | 09:36 AM
  #67
Not sure about them but I have huber 1330's
Unlimited jd is offline
Old 01-04-2015 | 09:39 AM
  #68
What's a rough guess on a price for those and how to they hold up/last?
Old 01-04-2015 | 09:45 AM
  #69
Love my Crash Boxes!
But there are PLENTY of transmission guys around the country that can economically make most transmissions hold up better then any bravo drives cone clutch
offshorexcursion is offline
Old 01-04-2015 | 09:50 AM
  #70
For the 4 vs 5 confusion, the easiest way to tell is the size of the pin that goes through the trim cylinders. 4s are 7/8" and 5s are 1". All the parts will fit in either case though. I was so confused when I bought mine
Rbesola is offline
